Looking for an odd size bolt
/ Looking for an odd size bolt #1
queen of spades
Anyone know where I can get this bolt:
7/16" hardened hex bolt (grade 8)
1 1/4" length
Important: I need 1/2" of the bolt shouldered. That's the hard part.. most shorter length hex bolts have threads all the way to the head. Have to have the 1/2 shoulder for the application.
(fwiw I've already been to ACE, box stores and a local Fastenal outlet)
/ Looking for an odd size bolt #2
That is kind of an odd bolt. If I'm reading your post correctly, you need a bolt threaded to within 1/2" of the head and that 1/2 inch should be the shoulder...not a typical shoulder bolt.
You can try companies that specialize in fasteners (rather then a hardware store). Do an internet search for "Fasteners" and "Bolts" to find a company close to you. One that comes to mind is a company named Fastenal, but I have no idea if they have an outlet near you.
The other possibility is this is a bolt made specially for a particular application. If that's the case, you'll need to contact the manufacturer of the tool or equipment you need it for (example: if you're working on a 1970 John Deere tractor, you'd need to contact a Deere dealer to buy the replacement bolt).
/ Looking for an odd size bolt #3
Can you cut back a longer bolt that has a shoulder?
I doubt anyone made a bolt special for that application. I'm sure the right supplier will have it for you. Ford/Dearborn was famous for using 7/16" bolts. Try a New Holand dealer.
/ Looking for an odd size bolt #4
Why do you need 1/2" shouldered? Are you using them for a Tension or Shear type of clamp up. Most ready made Grade 8 short bolts are fully threaded unless you order them special order or from a machine shop and it will really cost you.
Jim
/ Looking for an odd size bolt #5
Mcmaster Carr 91257A675
Closest I found 1 3/4 long have to buy 10 shoulder length is maybe
anyway take a look .
Not with 60 hardened fasteners.
I'll try this once..
The Italian tiller I bought (used, and with no model# anywhere) needed replacement tines. The closest I found was Caroli replacement tines. They have the same shape and hole alignment, but the holes are once size too small.
I tried drilling the holes larger with a carbide tipped bit and my 2hp drill press - barely scratched the surface.
So my only option is to put in 7/16" bolts. If I absolutely had to I could use non-shouldered bolts but that's not what came on it. I need to get as much metal-to-metal contact as these bolts will see a LOT of abuse.
/ Looking for an odd size bolt #8
I've never had a problem shortening grade 60 bolts. Done it a number of times. I doubt that in that application it will make a difference but perhaps. Good luck
/ Looking for an odd size bolt #9
Yea, a good cutoff blade in a small grinder will make short work of a grade 8 bolt.
/ Looking for an odd size bolt #10
If the tiller is Italian, it's probably metric. Why don't you replace with the proper metric size? M12 is slightly larger than 7/16". McMaster-Carr sells the metric grade 10.9 in both fully threaded and partially threaded lengths.
1-1/4" ~ 31 mm McMaster # 98093A751 is 30 mm fully threaded
and 1-3/4" ~ 45 mm McMaster # 98093A766 is partially threaded
Cut-off the excess with a cut-off saw blade.
Therein lies the problem. The holes in the tines are 1mm too small. The bolts for the existing tines are in fact 12mm. I would need 11mm shouldered bolts, but didn't find any such bolt (of any length) locally.
ACE had a 7/16 shouldered bolt that fit snug in the replacement tines. Using the 11mm (or 7/16) bolts means I'll have a little slop in the mounting holes, but I don't know what else to do about it.
And yes I have 60 bolts to put in.. so I'd like to avoid any cutting.
/ Looking for an odd size bolt #13
I got the picture now. The replacement tine's hole diameter isn't quite the same size as the old ones being removed.
/ Looking for an odd size bolt #14
Queen, Check BoltDepot.com. They have a shouldered bolt section if I recall right. I have ordered several times from them and they are fast and probably the lowest priced you will find.
Huey
/ Looking for an odd size bolt #16
Get some thin wall steel tubing and cut off 60 bushes that will step the tyne holes down to the bolt size you are using . A power hacksaw , bandsaw or a drop saw can do this if you use a positive stop so all are the same length .
/ Looking for an odd size bolt #17
Go to an aviation supply house.
AN, and MS bolts are generally only threaded 1 1/2 the diameter, just enough for a nut to grip plus 2-3 threads.
Would read, AN7-(eg;32=1", -64=2")
The AN series is equivilant to grade 8 and MS closer to G12.
/ Looking for an odd size bolt #18
Iron Horse beat me to it. Just cut some bushings out of tubing to take up the space of the larger holes.
/ Looking for an odd size bolt #19
Huey
Do like he says and get what you want from these guys. Fast service, good prices. They will have what you need, I've bought a lot from them. Way cheaper than Fastenal. But if you need to get them from a local store, go to Fasternal.
Bolt Depot - Nuts and Bolts, Screws and Fasteners online
Wayne
/ Looking for an odd size bolt #20
Another way of doing it, (not my first choice mind you, I like the bushing trick myself :)), but you could do it with a a 'tap end stud" which looks like this. Put a nut on the short end with some Locktite and it's close to what you want.
McMaster-Carr has them close to what you need.
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
Arrow Quip EF10 Top Bow No Sides (A64047)
Arrow Quip EF10...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
207279 (A52708)
207279 (A52708)
