Weird Lighting problem on Bx1830
   / Weird Lighting problem on Bx1830 #1
jimmer2880
Hagerstown, MD
'05 Kubota BX1830
Purchased my 1830 1 year ago. It had low hours and was dealer serviced (Original owner didn't do any of his own maintenance).
Other than a dent in the hood, it's only problems were a few electrical problems.
I had problems with the headlight not working - fixed that by replacing the switch
Then, had to replace the temp guage because it wasn't working either.
In order to get the flashers to work, I need to turn on the flasher switch AND one of the turn-signals (it doesn't matter which one).
Since the under-side of the dash isn't the easiest to get to, I was wondering if any of you had an idea? I'm hoping it's just a wire plugged into the wrong place.
   / Weird Lighting problem on Bx1830 #2
Possibly the wrong bulb in the wrong socket-if you have to leave the turn signal on to make it work. Its a "normally open switch" for either of them. perhaps the females were switched inadvertantly at some time if they are close, and a mirror and work light were not used.
My other thought is a hairline crack in a fuse, or a pinched low voltage wire.;)
   / Weird Lighting problem on Bx1830 #3
bad ground, I bet...
   / Weird Lighting problem on Bx1830 #4
I'm with joe L on this one....bad ground. Wired a couple of old cars now and most of the time I had a problem it was a ground problem.
Yes first post here. I have been lurking for awhile. Figured i would start contributing when I could to return the favor.
Thanks for the replies. If it ever stops snowing, I'll check the ground. If that's not it, I'll check the bulb. I didn't think about the bulb before.
I doubt it's the fust - I've been through them pretty good when I was tracking down the head-light problem.
   / Weird Lighting problem on Bx1830 #6
I doubt it's the fuse - I've been through them pretty good when I was tracking down the head-light problem.
It's easy to do and worth putting a new one in just to be sure. I've had a fuse show continuity while out of the machine but not while in the holder! I got lucky while testing that day..., but it could have been a -very- long day!
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
