Snow V Snow Plow
/ V Snow Plow #1
MossRoad
Super Moderator
South Bend, Indiana (near)
Power Trac PT425 2001 Model Year
Tracdoc's post regarding heavy snowfalls and clearing that first path up hill on a long drive got me to thinking about our Power Trac group discussions regarding V plows a few years ago, so I thought I would start a discussion on it.
A couple years ago several of us pondered V plows for the PT for busting open a path. With the quick attach being so easy to use, you could bust a path down the middle, run back to the garage and swap to the power angle plow in less than a minute and use it to do the sides. I think this would be a worthy project that could be accomplished fairly inexpensively. One could probably pick up a couple 36" lawn tractor snow plows at a junk yard pretty cheap, or a beat up pickup truck plow blade and cut it down the center, weld them into a V with some cross bars for bracing and attach a QA plate. You wouldn't need power angle on it. Heck, you could probably do most of the drive in 3 or 5 passes after "normal" snowfalls. The key would be setting it to the proper angles BEFORE welding in up so it sits flat on the drive.
Any thoughts?
/ V Snow Plow #2
Can you deliver a prototype to sw VA by Tues 02/09, MR?? :D I'll be very pleased to conduct all the preliminary design testing within 1 day, and even compile a comprehensive report for you.
I think this is a splendid concept, and since it would not require the hydraulics for power angling, it would pop on/off in a real jiffy. I'll be the first to admit I have no skills in this area, but many in our great group do, so it could move from concept to reality fairly quickly.
/ V Snow Plow
I have an old Myers snow plow out on our property that I could do this to, but we have not had enough snow in the last 10 years to justify it. I'm looking for a MIG welder to finish up my 2 year old backhoe project, so the plow project shouldn't take too long, but don't get your hopes up for this Tuesday! :p:D
/ V Snow Plow #4
Are you talking a V-plow that also converts to straight, angled etc. ? Or just a fixed V. ?
/ V Snow Plow #5
You guys should make a High speed V-plow like you see on some big county trucks, maybe even with the full wing plow setup too! :) :rolleyes:
Ok maybe I'm dreaming, or drooling for that matter :D
/ V Snow Plow
Nothing fancy, just a fixed V for busting down the middle of the drive on those rare deep snow days.
/ V Snow Plow #7
There's always a contrarian, I suppose.
I don't think a Power Trac would push a V plow in any significant snow. I just finished 2 days on the 1845 with the 6' blade. I had to herring bone plow through anything over 12" - we had 2 feet, so it was slow going. I used the blade as I would have a bucket, building the banks on the sides essentially with running starts to bash one blade load each direction. I think with a V plow, I'd just have driven in and stopped.
It would have worked fine in the light 6" we had last week, but in that I could blaze along throwing snow to the side like a real plow.
The answer, of course, for this past weekend, would have been the PT mounted blower. But, when I compare the cost of one of those with a boat slip in Ft. Pierce ...
/ V Snow Plow #8
Go for the boat slip!
All the best,
Peter
/ V Snow Plow
Snow is a funny thing. Wet heavy stuff 4" deep can cause me grief while 16" of fluffy stuff is easy work. The reason I think a V plow will work better than a straight blade for opening up that center path down my drive is this:
If I angle my blade to one side or the other and the snow is heavy enough, it will force the tractor to the side away from the angle. If I start getting forced to the side, I can usually stop, back up a bit, turn my blade straight, get a running start and start pushing again and keep pushing. A pile of snow builds in front of the blade and acts exactly like a V plow, pushing snow to either side. This gets a lane opened up from garage to street quickly in one pass. I think a V plow would work better than my "pile of snow in front of the blade" method. Of course, the only way to find out is to build one and compare side by side. :)
/ V Snow Plow #10
Yup, I think you should build one. Be sure to post pics. We like pics. :)
/ V Snow Plow #11
A friend just used two 6 X 6's angled to form the V with a piece across the back to form an A. You could make this a little wider than the PT, attach it to a two inch receiver and easily and cheaply connect it to a PT.
/ V Snow Plow #12
Actually a v plow works better than you might think. I had a plastic one that attached to the front of my van. It worked very well pushing snow. Just gave it to my son who had 20" of snow and he was very well pleased with it. I was thinking of making one out of 2 foot wide plywood and attaching it to the front of my blade just to make an initial cut down the the driveway
/ V Snow Plow #13
Any pics of these v plows? They sound interesting.
/ V Snow Plow #14
Studded chains would help a lot with a standard plow or V-plow. Even with them, my 7 1/2' blade will push me to the side sometimes but lifting the blade 1/2" usually solves that problem. The edge of the blade digging into the really hard packed snow (from being driven on by the cars) seems to be the cause. Just pushing against the snow itself even when deep does not usually throw the front of my tractor.
Ken
/ V Snow Plow
When I get that wet heavy stuff that sticks to the asphalt is when I get shoved side-to-side. If I have a base of packed snow, or it is really cold and the snow is powdery, then no problems with snow, even coming over the top of the plow.
We are supposed to get 6-12 tonight. Maybe I'll try some more plow videos! :D
/ V Snow Plow #16
That is the way they did it years ago using horses
/ V Snow Plow #17
Hi, MR. Well, I didn't get any calls from Roadway, Yellow Freight, etc. to tell me the V-plow was at their loading dock. :rolleyes: Notwithstanding, it still snowed yet again here overnight and this morning.
Fortunately, this time 'round it was only 5-6", and I finished off the driveway in about an hour. I forgot how much fun using the blade can be. Maybe He just wanted me to feel better today, after getting dumped on several times already....you know....to get my spirits up before the next blizzard :D
/ V Snow Plow #18
I like the thought of the wooden V plow, but would it be strong enough? Perhaps 4 x 4's on the bottom with plywood on the front about 18 inches high. Then you reinforce the plywood with 2 x 4's. Our snow is mostly wet. Of course we don't get a lot of it (except this year).
/ V Snow Plow #19
Tracdoc,
Find the materials and bring them over. It can be your first welding project!
Gravy
/ V Snow Plow
My guess is I would bust it hitting a frozen rock or something. :D
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2022 DODGE RAM 3500 FLATBED (A63569)
2022 DODGE RAM...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
