Kioti Dyno Upgrade
/ Kioti Dyno Upgrade #1
WVUNUT1985
Member
I have a 2001 Kioti LB1914 with a dyno. Does anyone know if there is an alternator upgrade for this tractor. I have read many post about Kubota upgrades, will the B series upgrade fit the LB 1914? Thanks
/ Kioti Dyno Upgrade #2
Why would you want to replace a generator with an alternator? Do you have some giant electrical load that the genny cannot keep up with?
I have the need for work lights and warning lights that will overload the dyno. I believe the dyno only puts out about 14 amps. Any suggestions would be appreciated.
/ Kioti Dyno Upgrade #4
Actually, you aren't overloading the genny, you are drawing from the battery. I'd be caught trying the lights with the genny first, then if you find the battery going down too fast, either add a second battery or go ahead with the alternator.
Thing is, an alternator, say a 65 amp unit, will not put out anywhere near its 65 amps unless it is (A) warm, and (B) almost at max RPMs. If you are rolling your diesel at 1800 RPMs, your 65 amp alternator may be pushing out, oh maybe 20 or 30 amps on a good day. Changing the pulley ratio will help.
Now your genny is making 14amps no matter what. Spin it, out comes 14 amps (goes by winding size, etc.). This is why they put one on there in the first place.
Again, a second battery may do a better job of running your lamps. Tally up the total watts, divide by 12 and that will give you the total amp draw. Multiply that by the number of hours you run the lights per day. Now you know the total amp-hours you need to have in your battery.
For example: 2 55 watt halogen work lights, plus 2 55 watt headlights plus 4 10 watt marker lights equals 260 watts divided by 12 equals 22 amps times 4 hours, so you need a battery with 88 amp hours storage. Lets round that up to 90. If your genny is charging at 14 amps, you are really only taking out a mere 32 amp hours total. Well within the capability of your battery.
If you double the size of your battery by adding a second one, then you will discharge both by half. It is well proven that doubling battery capacity more than doubles the battery life.
/ Kioti Dyno Upgrade #5
Another option is to use LED based work lights. They cost more than more classic varieties, but use a fraction of the energy. And they don't cost more than an upgraded alternator...
Mike
/ Kioti Dyno Upgrade #6
Hi i bought a kubota b7510hst and it come with a dyno and at the end of one month the battery died . So i called the dealer and he told me that there is an option on charging system . I bought a alternator kit for that 200.00$ sinse that time i do not have any problem . If you call the kioti dealer they will tell you if you can put a kit on it . GOOG LOCK
/ Kioti Dyno Upgrade #7
You might want to google "generator versus alternator" to verify what you stated above. An example below seems to imply the opposite...
Alternator and Generator Theory
/ Kioti Dyno Upgrade #8
I've never had a tractor with a generator on it, but I have several old muscle cars that I've restored that had old generators. Based on my experience and everyone I've ever spoken with, it's far better to go with an alternator. Being that I've installed A/C on all of my old cars, I never considered keeping the antique generators on them. I'd think if the old antique generators worked well they'd still be on cars and trucks. I can't say I've checked, but I doubt you'll find a single vehicle with an old generator on it. I'd swap to an alternator without a doubt.
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2005 International 4400 S/A Day Cab Truck Tractor (A61573)
2005 International...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
John Deere 450 (A64119)
John Deere 450...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
43023 (A59228)
43023 (A59228)
