Backhoe Looking for a used subframe Backhoe for a TC35
   / Looking for a used subframe Backhoe for a TC35 #11
My tc35 already has a NH subframe.
The NH758 hoe is made by Rhino, equivalent to the Rhino 85. It should
bolt right up to your subframe.
All these hoes are also "3-point backhoes", but can (and should!) be
mounted to a subframe. If you find a deal, you could adapt it to your
NH subframe.
   / Looking for a used subframe Backhoe for a TC35 #12
Okay so since you have the subframe you can use a BobCat, Kioti, or Rhino backhoe.
That will broaden your search....
   / Looking for a used subframe Backhoe for a TC35 #13
JJ,
What do you mean by you already have a subframe? Are you talking about the mounts on the tractor it self where the attachment pins are installed? -OR- Are you talking about the two long steel arms that go from the backhoe itself under the tractor and attach just forward of the bell housing?
I originally bought a used TC-35D with a 16LA front end loader and a 757-C backhoe. Years later I found a deal on a TC-45D, tractor only. So I bought the TC-45 and swapped everything over from the TC-35. I turned around and sold the TC-35 for $200.00 less than what I paid for the TC-45. Nice upgrade for $200.00. So I kind of have an idea of what's involved to install a backhoe on a class III Boomer. If I can help you just let me know. I'll be glad to shoot some pics for you tomorrow, weather permitting.
BTW....the only place the 3 pt. hitch comes in play here is at the top link mount on the tractor. You use the top link as a stabilizer/brace back to the backhoe frame. The lift arms have nothing to do with the installation.
JJ,
The part of the frame that bolts to the tractor. I believe the previous owner had a backhoe on it.
When I bought the tractor the dealer was going to sell me a used NH backhoe for $3000. I wish I jumped on it but who knew.
I have an old Dynahoe 290 TLB. It is huge and likes to sink in the soft ground. It has a clamshell bucket which comes in handy but its just too big and tears everything up. It weighs 20,000 lbs.
Do you have have of the above mentioned BH's available? Also, when you say I can use them I assume you mean I will have to modify them to fit?
   / Looking for a used subframe Backhoe for a TC35 #16
If your saying you have the subframe mount on your tractor already those backhoes will work on your machine.
New Holland uses the Rhino backhoe as their OEM supplier.
Bobcat is now using them as their OEM supplier also as did Kioti.
Do you have any in stock used or new? What is the price range?
   / Looking for a used subframe Backhoe for a TC35 #18
Are you saying the new curvy-boom Kioti KB2475 and the Bobcat hoes
for the CT230/CT235 are made by Rhino?
   / Looking for a used subframe Backhoe for a TC35 #19
No, Kioti used them in the past.
The new curved boom sub frame will still fit the old box styled Rhino backhoe.
   / Looking for a used subframe Backhoe for a TC35 #20
I have a very nice used backhoe currently on my TC35 I want to sell if anyone is interested $4200 obo takes it 5705066444
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2023 FORD F-250 (A58214)
2023 FORD F-250...
