opinions of backpack sprayers
   / opinions of backpack sprayers #1
GaryS
Gold Member
franklin park, pa
Kubota L3901 & LA525
I'm going to get a backpack sprayer. It looks like to two main sprayers are: Solo 425 Deluxe & Stihl SG20.
Anyone have opinions or experiences with these? They're roughly the same price.
gary
   / opinions of backpack sprayers #2
I've got a Solo. I'm going to buy a Stihl pretty soon. The Stihl is much better made as far as I can see just from looking at it. The Solo is OK. Just too much plastic. Since I can use another one I won't be buying another Solo.
   / opinions of backpack sprayers #3
I've had the Solo 425 for three years now and it has been fine. Large enough and comfortable enough to suit my needs. Only thing I may have done different is get a model that agitates mix as you pump - however I feel that my walking does a fair amount in keeping things mixed up.
Mike
   / opinions of backpack sprayers #4
I have a Solo sprayer. 4-5 gallons. It works.
Not real happy with it since the sprayer end leaks. The spray hose was just friction fitted so that with pressure it could blow out and whatever was in the sprayer would go whoosh out the hand control. :eek:
The little spray nozzles get blocked up which may be "my" fault since lately I have been using a dye to mark where I have sprayed. At this point I have glue the spray hose so it does not get blown out of the hand control.
I have had the Solo for 15 years or so. It has held up over time.
I did not know that Stihl has a sprayer. I would look at the Stihl and compare the two.
Later,
Dan
Here's a link to the Stihl sprayer: Stihl SG20
The problem is that all I can do is look at pictures. None of my local Stihl dealers stock the SG20 and I'm not aware of any local place that sells the Solo. I have to rely on the opinions of people that already own one :p
   / opinions of backpack sprayers #6
Look at Tractor Supply for Solo - I think there's one within 30 minutes of you.
Mike
   / opinions of backpack sprayers #7
I don't have experience with those but I put 50 or so gallons through a BP spayer every year. Wouldn't be without one. I have bigger electric sprayers but prefer the BP. This is my 3rd year on one I got from HFT for 17.00. Straps wouldn't stay on so they cleared them out. 2 screws fixed that. Sure do like it. Mark
   / opinions of backpack sprayers #8
My only complaint of the solo is the seal around the cover/cap/lid.
Don't like the spray liquid running down my back. But with some extra work, can get it to not leak.
   / opinions of backpack sprayers #9
I have a Solo, also. I like it...but have done a couple mods on it. I put a much better brass metal sprayer on it, (better than the el cheapo plastic one that came with it), and rigged up a holder for the sprayer out of a piece of PVC on the top of the tank.
I also spray about 50 gallons through it a year and it does the job. Solo has 2 types of these sprayers. One has the pump mechanism designed for liquids only, the other pump mechanism is designed for powders/solids mixed in with water for spraying. That mechanism will take more abrasive compounds. The big O ring drops out of the lid and that's what makes mine leak on occasion. Have to watch that.
You just can't beat a good backpack sprayer. You can get into places that a tractor or 4 wheeler can't go. I also use a dye with my Roundup.
I did not know that Stihl made sprayers either, and will look them over, also. I wonder what they cost?
   / opinions of backpack sprayers #10
I have the Stihl. I would have to look up what I paid as it has been four years or so. It is the only backpack sprayer that I ever owned so I cannot compare it but it worked just fine for me. My last property had about 10,000 feet of fence line that I sprayed with it a couple of times a year. The spray pattern was easily adjustable and laid out a consistent pattern.
I would buy another except I expect this one will last about as long as I can still load it up and go with it.
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
2021 Chevrolet Equinox LS SUV (A55853)
2021 Chevrolet...
2003 Big Tex 10PI...
2013 Jeep Grand Cherokee Laredo SUV (A55853)
2013 Jeep Grand...
2021 CATERPILLAR 259D3 SKID STEER (A52707)
2021 CATERPILLAR...
