New Home Construction Costs
/ New Home Construction Costs #1
scoutcub
Ohio
Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
Hello All -
I'm currently in the process of clearing some land for a home in northern Ohio, and trying to get some very ROUGH building/material figures for budgeting purposes.
A few specific questions come to mind first.....is the most expensive part of building the foundation and framing? Any formulas for cost of square footage for both? We're contemplating approx 3000' either ranch or 1 1/2 story.
And....to brick or stone the entire house (ala maintenance free) how much % would that add over conventional siding?
And....I'm assuming I should have a well, septic, and power to the site before starting foundation work?
I'm currently working overseas so about the only thing I can do from here is consult this fine board of experience....before I get home and engage an architect/builder. I am also following several building threads with great interest.....thanks in advance!
/ New Home Construction Costs #2
I believe it works out to around $100+ per sq foot?? Foundation well and septic will be extra.
/ New Home Construction Costs #3
I just last month signed the contract to start building on my new house in Bismarck Arkansas, (Hot Springs County). It is 2308 heated area and 4400 under roof for $187,500. I think the most expensive part is the kitchen. Depending on the amount you want to spend, cabinets can run you from $10K to $50k. I think my allowance was for $16K. $6.50 per sq foot for flooring including installation cost. $5600 for windows and exterior doors. $1500 for light fixtures. You will need to specify the level of quality that you want and materials to use. For instance if you want granite counter tops allow $30 per sq foot to install + cost of material. Natural stone flooring can go from $3-30 per sq foot or more depending on what you select. Concrete is about $165 per cubic yard in may area .
Payment for my house is $20K at finishing of foundation, rough in plumbing and slab floors.
$40K at completion of framing, decking and ordering brick.
$50K at completion of windows, doors, roofing, electrical, insulation and sheet rock, plumbing and HVAC rough in.
$20K at completion of interior finishing, paint, brick and vinyl siding
$57k at completion of interior trim, paint, closets,cabinets, electrical fixtures, HVAC units
Hope this helps. Note that payments may or may not necessarily reflect total cost of installation of those items.
/ New Home Construction Costs #4
Forget, that is $81 per sq foot cost for heated area, or $42.50 under roof cost. This doesn't include cost of land, sewer, water or electrical power to house. Some of the allowances are somewhat low and will likely spend a little more to upgrade. We have priced out windows and doors and we will be under on that, but flooring was figured on hardwood floor and we will be putting in some marble in about half the house so that will go up, but the hardwood flooring will be a little less I think so it may equal out. We were thinking of granite counter tops but will likely get formica at least in the kitchen.
Sewer and water costs were $6500 contracted thru a licensed plumber. That was the first thing I had put in to service my shop which I built last year.
Gary;
Hey thanks a lot, very useful info. I'm assuming you're hiring a GC to do everything? I was contemplating being the GC myself, and hiring the subs in. I'd like to pay cash as I go, until I'm out and have to finally pony up to the construction loan/mortgage. I can swing the well, septic and power, but I'm looking for rough figures on how much the foundation and rough framing would be separately. I'm already paying on the land, so that's not a factor. I'd like to go poured walls, probably 10 or 12" thick. I have the equipment to dig the foundation, so it would be the setup and pour only. But I think I read the foundation and framing are the 2 biggest costs in new construction?
I'm curious how the $$ breakdown works in your case? I can see the 20K for the concrete, and 40K for framing, but the 57K for interior work? Is that inclusive of just those items listed?
I do agree with you in that kitchen costs can go thru the roof. (no pun intended) We upgraded our counters to granite, pretty spendy but nice. And I could never understand why wooden boxes with door can cost so much?? (cabinets)
Again, thank you very much for sharing your home details...
/ New Home Construction Costs #6
Putting the house "in the dry" is the cheapest and quickest part. You can usually figure 1/3 of overall cost to do that, with a poured wall basement, that might be a little higher. Finishing the outside figure brick or stone will be twice as high as vinyl.
The inside is where the money is at, sheetrock walls are relevatively inexpensive, but everything else will be expensive. Your mechanicals (HVAC, Elec, Plumbing, etc) plus your kitchens, bath, and floor coverings and trim will be where the big money is at. Someone said $100/sq ft, that's pretty close on a nicely built and finished house. You can do $80/sq ft but not finished as nice.
If you act as the General Contractor, you can save a good 10-15%, but man, been there, done that, it is almost a fulltime job. A word of advice tho, if you start out with your every move to save money, then you will not be happy with the house in the end. Thinking you can cut back here and there to save on initial costs and come back in later for the niceties will only cost you dearly in the longrun. By far, any new construction is cheaper that Retro construction. The best time to get what you want is upfront, not later on. I say that with a bias tho, let me explain.
In late 2004, I bought a 1920 sf modular home and delivered price was $63,000. Vinyl siding, 7/12 roof pitch, 30 yr shingles, and I put in on a permanent brick/block foundation wall and about 45 piers. I bought the house raw, meaning sheetrock was hung, not finished, doors, mouldings, were included but not installed, cabinets were in place, and appliance incljuded. Long story short, 7 months and $12,000 later I moved in. I finished the entire inside, sheetrock, painting, trim/moldings, by myself.
Two years later, I built the front porch, 8' wide, 72' long with vinyl railings and columns, cost $10,000. I did all of that myself. This past Novemeber, I began the last addition (from my original plan in '04) of a carport (26x11), screen porch (16x18), covered deck (12x16), and a 240sf (16x15) addition to my den. Cost thus far, $14,000, of which, $7,000 is labor. I no longer can hold out to do my own framing so I had to contract that out.
So, all said and done, when finished, I will have 2,160 heated sf, plus carport, screened porch, deck, and front porch for a cost of about $110,000 and a helluva lot of sweat equity. I can easily sell for at least $175,000 but that's irrevelant, this is my last house.
I can't say it was worth it, for 5.5 years, I have worked on this house or on this property every day, some a little, many days all day. The good news is, I only owe about $25,000 with 4.5 years remaining. So, long-term, it might be worth it, short-term, and if you can afford it, go with a really good GC and a "turn key" deal.
/ New Home Construction Costs #7
Keep in mind that foundation costs in the south are generally much cheaper due to the freeze line. This is the reason basements are not very popular in the south.
/ New Home Construction Costs #8
Basements are not popular and are totally uncommon in these parts of the South not because of costs but because of water. The water table here is not too far down and there are ways around that (french drain system/sump pump) but it ain't worth it. We are mostly on very flat ground and surrounded by swamps/wetlands.
But yes, a basement does cost a good bit more and worth it in the right areas.
/ New Home Construction Costs #9
Price to build a house varies with where you are building it. I've built brand new, all brick houses for $55 a foot and sold them for $75 a ft here in East Texas. No basements and slab foundtions. Brick is cheap hear and the labor is also very affordable. Rock is becoming very popular here, and used on almost all the higher end homes. Type of rock and how much is used if a big factor in the cost.
In CA, I worked on homes that cost close to $300 a ft and sold for $320 a ft. Those homes are crap compared to what I can build for $80 a ft here. A $100 sq ft house here is very high end, granite counters, tile floors and vaulted ceilings with a ton of very nice trim work.
When planning a house, a rectangle is going the be the cheapest to build. Think of a moble home and you'll see where the cost savings are. Add to the rectangle and the price to build goes up because it takes longer to build. Foundation work can be a small part of the house, or a big part. It really depends on what you are working with. Once the foundation is in place, it's pretty easy to seal in a house for $15 a ft.
The real money is in finishing the house out. Cabinets, flooring, lights, and trim are just a small part of where all the money goes. Some people are happy with ten dollar door knobs, others have to have $300 door knobs. Carpet is the cheapest flooring, but you don't want it everywhere.
Being your own GC always sounds like a good way to save money, but a good GC will build a much better house then you ever will, and he'll do it both faster and cheaper then you can. Since you don't know what you are doing, and you don't know who you will be hiring, you don't know what you are getting. Here, 15% is the going rate for a good GC to build a house.
One of the trade magazines that I read talked to some of the bigger home builders in the country. They were trying to find ways to cut costs in building a house. Approximately 1/3 of the cost to build the house is materials, the rest is labor and fees. Keep that in mind when trying to figure where you can save money and if you are capable of getting subs to do a quality job for less money, or if you even know what the rate is that a GC would pay. Can you hire a sheetrock crew for less then I can? Do you know if they are BS'ing you in telling you about a special rate to keep his guys busy during these slow times? That's a very common theme going on right now. Do you know what Code is for a house and if you're house is framed properly? If you are building in an area that requires permits, that will help to make sure it' done right because the inspector will do all the checking. If it's an area without permits, then anything is possible.
If I was you, I'd concentrate on finding the best possible plan for you. Watch out for trends, and what's the latest craze. Contact at least five builders in the area you will be building and ask them what their price range is to build a house like the one you want. Don't ask hypotheticals, they can't give you an answer for something that's not real, but with a real plan, they should be able to give you a working number with a budget on what you can use to finish it off to stay in that price range. Be sure to talk to at least five builders. If they have been in business for any time at all, they are good salesman and probaby very personable. Most will make you feel right at home and become your best friend. This is neither good or bad, it's just how most do business.
After you've met will all five, or more, then you can start thinking about the budget, and if you want to try to be the GC.
When given a bid, or budget for a house, you are receiveing hard numbers and soft numbers. Some things can't be changed. You have to have the lumber, but you don't have to have granite counters. It's those things that you use to finish it off is where you can save money, or make it nicer. My budgets are usually pretty fluid once we get to the finish part of a job. I can be way under budget until the end, and then it's just crazy how the money gets spent and how far over budget we go.
The better your plan, the more detail that you consider, the fewer surprises you'll have.
Good luck,
Eddie
/ New Home Construction Costs #10
Great post eddie, I forgot to mention the part about details and change-order. By far, "change-orders" are the most expensive part of building. Some builders are a little more flexible than others but mostly, when you talk change-order, you talk mucho more dollars.
/ New Home Construction Costs #11
Scoutcub:
Eddie is a wealth of knowledge when it comes to residential construction.
I also second Herd's comments about 'change orders' driving costs up significantly depending on the request.
Unfortunately things are so different price wise across the country that it makes it tough for people to give more definitive numbers for you on forums like this. California is EXPENSIVE, while the Midwesterners have it made for getting a house built at reasonable costs. Colorado is a mini California :mad: in that prices for construction are higher than they probably should be.
Do you have a decent library near you? If so, you might check the R.S. Means estimating books for your area (e.g. state). That may be of help.
Another rough and I do mean rough way to guesstimate is to check property tax records for your area, and for homes built within the last five years; then check for sales price and finished square footage. Take the price and divide by finished square footage to arrive at price per square foot. I did this for the three homes on the block where we have property and found prices ranging from ~$114/sq ft to ~$175/sq ft. I've been in both of the houses and they are by the same builder and are the same floor plan. The low cost one looks like crap, while the high cost one is quite nice.
/ New Home Construction Costs #12
Pretty good and accurate info. so far. $100/finished sq.ft would be midgrade here. I noticed you mentioned architect in your future. If going that route, they should have a portfolio which includes recommended GC's. As others have said, depending on.......15% is a decent ballpark and lots of headaches for the homeowner can disappear. The architect will have hands on and the GC becomes your job foreman and is your "go to" person. Depending on the design, the architect and GC should understand all of the complexities before they start.
Without a stamped building plan, it's almost impossible to quote a foundation. Poured walls, ICF, slab on grade, footers and block and/or a combination of all can be done. How about a basement under the 4 car garage? The amount of steel,decking, reinforcing and grading for a job like that is way different than a basement under a 20x20 wing.
Current pricing is $110/yard for concrete and $300/hr for a pumper plus steel and labor.
An average building lot - well, septic and electric service should come in between 15 and 20K. Non standard like a septic mound can double that. Permits and fees are very local things and let's not forget school allocation fees and road frontage fees and.......
/ New Home Construction Costs #13
Yes, I'd agree that there is probably a 200% difference just depending on the build quality. Not saying the lower end is the equal of a wobbly box built on sight, but just the grade of materials and your design. Because of my driveway, parking areas, 1660 sq. ft. wrap around brick and concrete porch (covered of course with 18 ceiling fans) and barns, I've used over 2000 sq. yds. of concrete already. Since we have guests over and frequently host parties, I opted for mostly quartz counter tops with some granite. That runs up the costs. Also, I have no carpeting; only stone, ceramic tile and hardwood flooring. That kills the flooring bill. Add in a large inground pool with even more concrete and custom brick work and a 1500 sq. ft. poolhouse made to match the main house and costs went up even more.
Then, as some have noted, kitchens and bathrooms are expensive. I have 7 baths in all with two kitchens. It's really easy to make sq. ft. estimates unrealistic if you build to suit yourself and it's your final home for life. My first home was only about 38% the cost per sq. ft. as this one, but I knew I wouldn't stay there but maybe 5 years. Using higher quality (read; more expensive) materials wouldn't pay off in resale, at least in my area. Then, couple all of that along with my stubborn 'pay as you go - no mortgage plan, it forced the construction to last nearly 15 years. Now that I'm finally nearing final completion, I'm finding that I need to go back and re-do some things and finish some things that slipped my mind, such as crown molding. That got put off when I opted for all custom solid wood doors. They look really nice, but sometimes are bad if the kids slam a 90 pound door. I keep telling them that they need to be careful because if someone's fingers are in the door, those heavy solid wood doors will take a finger right off.
Good luck!
/ New Home Construction Costs #14
Scoutcub, Our home was built not far from you (Malvern) in 2003. It is 2x6 construction, 9' ceilings, hardwood and tile floors through out, with seamless steel siding, five french doors, a full 12 course block basement, and a wrap around Ipe deck. Back in 2003 it was built for about $125/sqft (the best I can figure). It is a very well built home. If you are going to be the GC you could knock some off that price.
As far as your specific question about the breakdown for foundation, framing, and so on, I really can't help you there.
/ New Home Construction Costs #15
I'm doing something similar to Dargo. My house is just 1,000 sq ft, and I built it myself for $35 a ft. I have a 24x30 shop and all sorts of storage areas for work and the land. If I had just built the living area, it would have been quite a bit less. It's possible to build a house yourself for very little, but you have to remember that it will take allot longer, and you will have to take a step back every now and then to keep moving forward.
We tried staining the concrete to save money on flooring in part of the house. We liked it at first, and from what others said, it was a hit. After a few years, we've come to hate it and have tiled over most of it. My family room is still concrete and we want to put wood down, but it's low on our list of things to do.
We have three bedrooms and two full bathrooms. With two kids and a wife in a small house, we'ver realized that we need another bathroom, so I'm going to add on another 200 sq ft for a really nice bathroom. This will be expesive sq footage and ad qiite a bit to my build cost. Of course, it will also add allot of value to my house without changing the footprint or increasing my property tax.
Currently I'm taxed for a house valued at $60,000 and I had to challenge the tax assesor to get it down to that, which I won.
I have two more house builds in my for what I live. My next one will be a nicer family home next to this one. I'm in no rush to build it, or spend the money, but the plans are in place and it will happen one of these years.
The last house I build will be after I sell this place and buy my dream ranch. That one will probably take me ten years to build.
Doing it yourself is a great way to save a bunch of money, but it takes so much longer to finish it. You get so much done, move in, make ajustments, put things off and live with things the way they are until you get the time and money to finish them off. Then while living there, you want to make changes, and there goes the budget. LOL
For a single family, residential home, I'm very hesitant on hiring an archetect. If you go to www.eplans. com and enter the size of the house you want, you'll be overwhelmed with floorplans. You can narrow it down by style, footprint and features, but even then, there will be more then you could think of.
Pretty much every possible way to draw a floorplan has already been thought up. There really isn't anything new out there, just new ways to do it. Rooms need to be so big, and you have to have so many rooms. Most homes are very functional up to 2,000 sq ft. After that, you start to get space that you never use, and is more for show then function. Two places to eat when 90% of the time you eat in front of the TV is a waste of space in my opinion. A formal dining room is very nice, but one of those expeses that you can eliminate real easily. Two and three living rooms are also an expense that rarely gets used. I've been in allot of homes that have rooms just to display the fancy furniture, but is never used.
With a floorplan that you like, you can then figure out how to finish it off. Ignore what the outside of the house looks like in the drawing. That can be changed to anything. Log cabin floorplans are always very open, moble home floor plans are always the best laid out for cost savings.
I think that just about every contractor out there can build a house from a drawing on a napkin. It happens all the time, and it's really quite simple to build a house from a very basic scetch. Find the plan that you like, modify it to fit your needs and use that in your bid process.
Of course, another advantage of hiring a GC is that he'll be able to look at your plan and tell you if it's the most expensive way to build, due to waste, span or man hours. He will also be able to offer suggestions that will save you money, but still end up with something similar.
Eddie
/ New Home Construction Costs #16
The township I live in, Napoleon MI, which has a median household income of 43k/yr, revised their zoning rules in 2005 to require mandatory architect plans to be submitted as part of the permitting process. Not only that, but if erecting any "structure", driveway or fence, a survey is also required. These 2 items alone can add several thousand $ to the cost of any project and may be more expensive than the project itself. Considering that the median home price in 2008 was only $108k, I think that the concept of affordability in the Midwest is a little overstated.
I am wanting to add a workshop to my property, so I started reading the zoning rules. It turns out that if I built a detached structure (best from a construction simplicity and insurance standpoint) I am limited to a little over 700sq ft and the highest part of the roof may not exceed 15 ft in height. That does not sound good when I intend to be able to drive my loader backhoe inside to work on it out of the weather - I am guessing that I need a door at least 10ft high. If I build the shop attached to the house, there is no limitation to roof height and the floor area goes up to a total of 1/3 coverage of the lot. The problem is that our access road runs down the west side and (with a curve) the south side of the property. And the township plan (dated in the 50's) shows another (non-existent) road to the east of the property. The lot is only 1/4 acre to begin with and now I have 25ft setbacks on 3 sides and 20ft on the side I could attach the shop to. The original setbacks were much smaller (more like 8 ft) and the limitations to detached buildings didn't exist either, so my neighbors have huge double story garages with either a shop below or storage above.
The best part about the process is that the survey revealed that the developer put the road in the wrong place and the road actually sits on 30 ft of my property. Furthermore, it turns out that my neighbor on the south side has his driveway almost entirely running through my property. Basically there is no way the county will move the road and if I was to push on the driveway issue with the neighbor, the only way things could be made legal would be for me to sell him a piece of my lot, thus hemming me in even more.
What I am trying to do right now is to put the shop on the neighbors side, attached to the house, and change the neighbors driveway such that it becomes a common driveway servicing the neighbor and my shop. I should be able to attain support from the neighbor for this plan, since all the alternatives (at least in the short term) would cause him a lot of hardship, since he hardly even has sufficient space to back out the garage and turn without driving on my land. The complicated bit is that I will need a variance from the township approving a reduced setback for the shop on the neighbors side, along with the common driveway. Since the neighbor is the only household affected in any way, I am hoping that with his support the township will use common sense and give me the variance. If they refuse it will be ugly.
This situation with its different facets simply illustrates how regimented life has become in a rural suburb in a relatively low population area in the midwest. One expects to find this kind of regimentation in gated communities in Florida, but not here.
/ New Home Construction Costs #17
Great info Eddie.
Local building codes can be a factor in costs also. The county where I live and the county to the north both require an architect's stamp on the print before they'll issue a permit. That adds to the cost. We built some houses in a town that required flitch beams (1/2" steel plate sandwiched between 2X12's) for headers. That adds to the cost.
It's common for a GC to charge 15%. It least it used to be that way before the market tanked. I know in my area that GC's will gladly work for less right now. To give an example of how bad things are here in 2008 there were 350-some new houses built in a neighboring town. In 2009 there was one! Its a buyers market right now.
How much can a DIY-GC shave off the 15%? They won't save a cent on concrete. In fact they may pay more. They can probably buy dimension lumber for about the same price. It's unlikely they will ever buy windows, cabinets, trim, and fixtures for what a contractor can. The DIY-GC will burn up much of the 15% savings just in added material costs. Add in the inevitable construction delays that inexperience will cause and the price could well exceed what a GC would charge.
Eddie mentioned hard and soft prices. The customer can save themselves allot of money by picking everything out before the bidding process, and not making changes during construction. This is where a good GC can really earn his money. Sit down and discuss your needs with a GC. Ask lots of questions. He'll have some good suggestions. The more decisions that are made before the bidding process the smoother things will go during construction. Plus you'll eliminate allot of unexpected costs. A good GC will be willing to lock in a firm price. The only exceptions being change orders and underground obstructions (rock). The next best thing would be to use allowances for fixtures and finishes. Just be sure the GC and subs are using realistic prices for their allowances.
I haven't seen anyone talk about the pay as you go plan. Mortgage rates are very low right now. Lock in your mortgage rate now!
More about GC's. Talk with several. Check their references, ask lots of questions. Pick the one or two you think will work best with you, THEN get prices. The bottom line isn't the amount you spend, it's the value you get for your investment. Sometimes an extra 2 or 3% ...or even 15% is money well spent!
/ New Home Construction Costs #18
Here is what we are completing as I write this. We started with a 2000+ sq foot house build by a builder in about 1974. We added a new kitchen and mudroom on for an additional 1200 sq'. We joined the existing first floor bath with shower toilet, sink with an extension bath, moving the toilet into the new area, adding a jet tub and radiant heat throughout the downstairs. We replaced the old hydronic furnace/boiler with a Buderus gas unit, took out the 2 stack chimney and its 'pre-fab' exterior framing and replaced the wood burning insert /fireplace's vent stack with a rear vent gas insert. Now all heating is supplied by a 1000 gallon in ground propane tank and a 20Kw B&S generator with transfer switch and load shed center. The dining room also has a gas fireplace and the Viking range is fed by propane too. We went with locally built custom birch cabinets and granite counter tops, and island with granite, a separate roll around bake center for my daughter, with a locally quarried marble top and custom chandeliers for the dining room table and over the island area.
The builder and I did the design off the usual back of a napkin and he quoted me around 135/sq' for structure. We used architectural shingles, and standing seam metal roofing, with a custom designed atrium area with sno-melt roof tubing. We excavated for a 4' concrete foundation crawl space under the addition with a rat slab. We used an engineered truss system for the addition roof/ceilings which are 12' feet at peak in dining room/kitchen area and closed cell spray foam throughout all new construction. Lots of Marvin Integrity line windows, which have fiberglass frames for best energy efficiency, etc and three Velux skylites with electric op. blinds added to inside the fixed pane interior frames.
My point is I act somewhat like my own GC but have one on site running his crew for the actual build. The actual GC and I make all decisions as we go, as to material choice, where to buy and how much. I use my own electrician and the foundation was sub-contracted for which the GC gets his percentage. He also gets a percentage on the plumber, tile guy, etc. There was no % by GC on cabinets, electric, tile, granite, electric fixtures, and many other items which I specked and paid for in advance, out of pocket. There is no change order situation since we coordinate things as we see the need and there is very little to change. I am on site pretty much every day since middle of March'09 and we are still doing punch list on house/addition. We also took on a 40'd x 30'w barn with a 12'w x 40'd boat bay with overhang roof off the barn's side. The barn is a prefab factory built unit by a custom home outfit nearby our area. For that extra piece of work and its value to my builder/GC he charges me NO percent on the building structure, but does charge for the subs, etc. He did this to allow himself to become one of their listed premier builders and to keep my project moving without any stop of work from beginning to end.
We just renegotiated his percentage on the subs and materials and he was willing to cut his % in half. This is great for me and allows me to keep things going and to hopefully come to completion of the entire project with about a year time frame.
So my points are you can save a lot of money by working out a special 'contract' with the GC you choose and we used no architects, except for the barn because it came with one in the package price for the structure. (Just add water- instant architect;) )
By doing things this way I am actively involved in every step but my only tools are the phone, my eyes and the net and pc use for constant communication with all involved. It saves a ton on headaches and backaches and still manages to keep the overall costs down as low as is possible working with a professional GC on site.
BTW, I wanted to mention Hardiboard as a siding consideration for your structure. It is cementaceous fiberboard and looks like clapboard, and comes in a variety of colors. We actually tore off the existing houses cedar shakes (dryrotted), and used Hardiboard for the entire structure and replaced the old 1974 versions Andersens with new Marvins and 1' Blueboard on the entire structure below the siding. Hardiboard comes with a 30 yr. warranty and with a second coat of paint within 180m days allows for another 15 year extension to the warranty. It is also fire rated so it adds another layer of protection to your house. Virtually maintenance free.
Oh yeah, one last item. Our prior septic leach field had already failed and needed replacing so we had to build a mound system and septic pump station at large expense as well as tie in to the system with a separate septic tank for the barn's second floor apartment.
All in all I'm very happy with the results of the entire project but it has been a long and very expensive undertaking for what will hopefully be our final home.:)
Hope this helps.
/ New Home Construction Costs #19
I was the GC on my house project and I will tell you after it was completed, I vegged for a few months. The missus couldn't get a team of horses to get me out of my easy chair. With that said, I have to say I really enjoyed doing the project. One of the key elements is not to always take the less expensive way. I built a 2400 sf ranch with a full poured wall, walkout basement. You see, I learned a lot helping other friends build their house. I was mostly the grunt labor for the different projects that were going on. That way I built up time from all of them and they came over to help me on different parts of the project. I watched and paid attention to a lot of what was going on. I also seen some things I would not except and saw some other thing I thought were pretty cool.
Some things I learned, I in no way had enough budgeted for landscaping... Well I did for my taste, but the little boss wanted something totally different than what I was thinking. I am here to tell you boulders are expensive, especially 4 leads of boulders. Second, all the plants she put in would have scared the monkeys away in the jungle....I couldn't tell you the name of a tenth of them, but she could.
Kitchen, bathes and lighting can get out of sight. Who would've of thought pine cabinets wasn't ok for the boss. We ended up all hickory with granite everywhere including the walk-in showers.
For my own peace of mind I overbuilt everything, upgraded the trusses, floors, shingles. Didn't want to do them again. Glad I did, because I have absolutely no deflection on my floors. We did the tile, installed the cabinets, lights, doors, siding and painting too.
I subbed out the flat work, poured walls, framing, plumbing, mechanicals, septic, well and drywall. The rest we pretty much did. I am here to tell you installing 1400 sf of tile will make a old man out of you in a hurry.
I prepped the land and cut in the diveway (400 ft).....any reason to get on the big toys, I used it.
But there was significant satisfaction after it was all complete and I know everything was done the was it was supposed to be done. Key element was also making sure you used subs that have a good reputation and you have seen their work. While it gets time consuming to go check, make sure you do.
We also had building inspections along the way and the inspectors made sure they checked it all real close because I was the home owner building his own house. I was frustrated at first then thought later of it and appreciated them looking as close as they did. The real question, would I do it again.....probably so, but I sure won't lay the dang tile again.
All in all it came out great and I can carry the bragging rights that I built it myself...or at least some of it. I would estimate I saved 50 -60k on GC charges and another 30k or so soing some of the work we did.
/ New Home Construction Costs #20
In 2007 mine worked out to about $105 and that is with zero general contractor fee, paying the subs myself. We got premium Marvin wood windows, mostly real hardwood floors, foam insulation, lots of cedar, cement floored balcony on the second floor, granite countertops, custom cabinets, etc. I think everything is high quality, but not fancy or pretentious at all. Just country. If I had it to do over I'd like more foam insulation, metal roof, and rock instead of brick. But the cost would have been considerably more.
We have about 2200 heated but room for 2 more bedrooms as bonus in the attic space. Only 2 bedrooms and a sleeping loft area.
I have never regretted any of the money we spent on high quality such as the windows. Only the money we didn't spend. For example I wish our fireplace was deeper, we use it quite a bit. Also wish I had put in 2 tankless water heaters instead of one. Takes a while to get hot water from one end of the house to the other. These were cost cutting measures that I would change if I did it again.
