JD loaer - QA, Global or Deere?
   / JD loaer - QA, Global or Deere? #1
andrewj
South Carolina
JD 5105
confused as there are three ways of attaching a bucket to the loader! I dropped off my 5105 to get the 553 loader yesterday. Looking at 73 inch heavy duty bucket. Just not sure about the attachment, any input is appreciated!
   / JD loaer - QA, Global or Deere? #2
I just responded to your other post...
I would suggest the SSQA.
   / JD loaer - QA, Global or Deere? #3
What Kenny said.
Global would be my second choice, global would be my first choice if the loader was any bigger.
   / JD loaer - QA, Global or Deere? #4
If the 'global' is what I would call 'euro style' I'll vote for that. Stronger and more easy to use than a SSL coupler. The last coupler I would consider would be a proprietaty style such as Deere's.
   / JD loaer - QA, Global or Deere? #5
Global= euro
   / JD loaer - QA, Global or Deere? #6
I really looked at the global loader attachment on the JD website. I couldn't figure out if the lower pin configuration was an electric over hydraulic or straight electric or straight hydraulic operator.
And the pin configuration appeared to be a likely source of frustration when using with ice, snow or that wonderful combination of ice, snow and mud (or throw in a little hay and manure into the whole mix). It seemed to me that getting the lower pins either in or out with those kinds of conditions would be a time of "blessing the implement" and thinking of ways you'd like to torture the engineers who designed it..
I have the SSQA and the neighbor has the SSQA on his JD 542 FEL. It works and it's real simple..
AKfish
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
197359 (A50458)
197359 (A50458)
2007 Toyota Camry Sedan (A48082)
2007 Toyota Camry...
2008 Ford F-250 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2017 Buffalo Turbine BT-CYC8KK Cyclone 8000 S/A Towable Debris Blower (A49346)
2017 Buffalo...
