RTV 900 rear halfshaft questions
   / RTV 900 rear halfshaft questions #1
Steadyfast
Hi all, new to the forums, long time mechanic and off roader.
I have a used RTV 900G I'm repairing to use. It has some U Joint troubles in back and before I dive in to fix it all, I have a few questions.
1. What holds the outer halves of the rear half shafts into the carrier housing that is welded to the crossmember (that all has to come out together)? Press fit? Hidden snap ring or lock screws?
2. Do the experts here suggest replacement of entire rear halfshaft assys or just rebuild with bearings, seals, u-joints, etc etc, if still usable, even though splines are badly rusted and getting a bit of slack?
I have the carrier out from under the thing and before I go pressing, heating, or beating I need to know what holds those outer halves in place. Does the wheel flange serve to clamp the bearings against a machined shoulder inside?
Also is there any source for aftermarket pieces or is it all Kubota only stuff? It also has a cracked head and I'll be looking for one of them as well.
Thanks in advance...;)
   / RTV 900 rear halfshaft questions #2
just done both sides of mine take the outer nut off and use a piece of wood and a hammer it drives in one side came out pretty easy other side i caved the end in where the carter key goes in and messed the threads up i was able to grind the thread down and save it. it cost 286.99 new had to replace bearing and seals on both side. also tried a puller didnt work
Thanks, I thought it was just a semi press fit. I plan to change the shafts and bearings as the hubs were loose and ate most of the splines so they're junk, and I can just hammer them out. I'll clean up the bearing locations with a flap wheel on my die grinder, they should go back together well.
Thanks again.
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2003 Big Tex 10PI...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2014 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A58214)
2014 HEIL TRAILER...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
