Waste oil heater for my garage.
   / Waste oil heater for my garage. #81
A guy around here had a five gallon metal can of oil and sent it via a steel tube and then a small ball valve to cut the flow to a drip and has the tube going in to the fire chamber it simply drops a drop of oil on the already burning wood.I don't think id want to try it myself..
   / Waste oil heater for my garage. #82
I converted my 40 year old oil stove to wood, by putting a pan over the air entrance/oil burning puddle to distribute the air through the 20 or so half inch holes i drilled into it. IT works great for me, its not as dangerous as a waste oil heater (old oil has clods which will make you open the ball valve a bit more to keep it burning, untill the clod is through and the oil is heated so it runs down like gasoline, drowning the fire and overflowing into the shop)
I could only burn an entire year of oil changes in just 3 winter days. Nowadays i just throw a pint of oil over the wood everytime i light it. (with the propane torch) That will help me get rid of my old engine oil, but its safe to stack a wheelbarrow full of wood in it and let it burn. With engine oil i had to adjust the flow every 15 minutes, and my workshop was full of thick oil smell...
If you look at my build there is a pan under my heater for any spills. This pan will hold about 10 gallons, the bucket that feeds the burner holds 5 gallons.
   / Waste oil heater for my garage. #84
Here is one for you wood burning guys.
YouTube - Wood & Waste Oil Burning stove
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58018)
2014 FREIGHTLINER...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2020 DRAGON ESP...
SKID STEER ATTACHMENT (A58216)
SKID STEER...
(INOP) FORD 550 BACKHOE (A58374)
(INOP) FORD 550...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
