Flail Mower ferri ZME155 flail mower?
/ ferri ZME155 flail mower? #1
bc realtor
Vancouver Island BC
Antonio Carrero TTR4400
I have been kicking around the idea of a flail mower for some time now. My thoughts have kept returning to the Ferri ZME155. Has anyone here got one and give me there likes and dislikes about the unit?
I am going to run it on my AC ttr4400 35hp at the pto for mowing down brambles and scotch broom mainly. I was also wondering if the unit would handle hammer knives?
/ ferri ZME155 flail mower? #2
That's the first reference to a Ferri flail mower I've seen on TBN. No experience that I know of. Is it Italian made? Italy seems to have a number of flail mower companies all of which produce nice products at moderate cost. The US made flails are typically heavier duty and much more expensive. The only other source I am aware of is China which produces cheap versions of unknown quality.
/ ferri ZME155 flail mower? #3
Flail mower is another attachment that is on my list of used attachments to look out for in my travels. I could not justify buying a new one but sooner or later I will find one.;)
these flail mowers are italian made. they can be offset by six feet and tilt down 45 degrees and up 90. looks to be a very vesitile machine.
Slope Mower ZME 155 | Ferri America
/ ferri ZME155 flail mower? #5
Looks nice if you need a slope mower. I'm sure that tilting capability increases the cost quite a bit over a regular flail though. Compare to the Caroni TM1900 for example which can be had delivered for about $2000 from AgriSupply (at least on the east coast).
I got a quote for $6300 on the unit but I know of a used one for $4500. I think the factor of not having to drive over the stuff that I would be cutting and also the factor that nothing here is flat, your either on the water or a hill. My tractor is an Antonio carrero so It already has great slope abilities and this would be giving it that much extra.
/ ferri ZME155 flail mower? #7
look for a used alamo super heavy duty, i picked up my 7 footer for 700, and re built it painted it, looks and runs brand new
/ ferri ZME155 flail mower? #8
Did you get one?
I just bought a nice used one for $2700 (+ 25% VAT). So far just made a test run but seems to work fine.
/Marcus
/ ferri ZME155 flail mower? #9
Did you get one?
/Marcus
How do you like the mower so far? How is the build quality? I'm thinking about getting a MT200 flail mower for mowing cover crops on my farm.
/ ferri ZME155 flail mower? #11
I recently purchased one for $1,500. Needed some work on the gear box and new flail blades... seems like a good deal now. I use this with my JD 4320... with the offset it works very nice on my steep ditches - safe and handy. Next I am planning to test this for trimming grape vines.
/ ferri ZME155 flail mower? #12
Hello RWFalkenstein,
I want to welcome you as the newest Member of the Flail Mower Nations.
(no passport required)
/ ferri ZME155 flail mower? #13
You have to check to see what type of rotor the unit has as standard
equipment before you make any decisions.
A flail mower will have separate flail mower rotor for scoop knives or side slicers.
Swivel hammers are reserved for forestry flail mowers.
You have a good mule in the Antonio Carrero tractor. Did you purchase it from the
importer in California??
/ ferri ZME155 flail mower? #14
I purchased it used locally from a guy who used it on an estate. Works good for me.
/ ferri ZME155 flail mower? #15
As long as you take care of it it will outlast your current mule and also work well
with a larger one if you upgrade to a larger mule.
