? About radio install on JD 4520
   / ? About radio install on JD 4520 #1
xrjohndeere
Gold Member
Mo
2021 Kubota L4060 HST
I am getting my new cab 4520 in Feb. I ordered it with the speaker kit but not the radio. I have a cd/dvd/blue tooth radio to install in it. Is the adapter plug I need a plug from volkswagon part #vw01b? Do I need some special adapter kit to install the radio? I have never seen how much room is up there. What size are the factory speakers? I am thinking about changing them out while I have it apart. Is there any room up there in the header to add additional speakers, amp, woofer, etc? Before anyone says anything about the DVD player this is a stero made by Oygen audio that a friend of mine is a dealer for. He had this display unit that he sold me at below cost, cheaper than I could buy anything else with half of the options. With the big LCD screen I can see the numbers well and is equiped so I can hook up a back up camera. Thanks for the advise.
   / ? About radio install on JD 4520 #2
I'm just curious how you intend to use the backup camera?
I doubt I use the back up camera option. It is just one of the features on the stereo. I have plugs where I can hook it up to a bigger monitor. I have thought about hooking it up on a switch and putting the bigger monitior on the back side of the sunvisor. This would be handy for me brush hogging because I have bulging disks in my neck and looking around behind me really kills my neck. Just a thought. This will be the nicest and last tractor I will own so I might as well pimp it out. While I am at it I am thinking about a way to put plugs on so I can connect external speakers for when I am working outside and want to listen to the stereo. The speakers would be removeable, maybe attach with quick connects. Crazy I know!
   / ? About radio install on JD 4520 #4
Is the radio you are installing a single DIN unit? If so, you will have no problem with the installation. There is no special adapter kit needed. If it is a Dual DIN, I believe there will be problems (not enough room). The adapter plug you mentioned is the correct one. I have attached some pics of my recent radio install. Sorry, but the pics are after the installation was complete, not as I was installing.
It looks like it is the same size as yours so I guess it is a single din. How do you like your blue tooth? Have you used it yet? Thanks for the pics and the info. :D
   / ? About radio install on JD 4520 #6
I like the Bluetooth feature on my radio because I downloaded Slacker Radio (Free, no need to purchase satellite radio) on my BlackBerry Storm and I can stream that or other MP3 music files with no wires. I use the BT feature to stream music from my phone every time I operate the tractor. The phone feature is ok but I have to idle the tractor to keep the background noise from interfering with the built-in mic during conversations. You mentioned a big LCD screen in your first post and the ones that I have seen are all Dual DIN. Do you have pictures of the radio or a website that it can be viewed at?
No pictures yet. The screen is not very big, maybe 2x3". I was looking at maybe putting in a bigger LCD for a rear view camera when brushhogging. While you had yours apart did it look like you had enough room to put in two more speakers? I just want to get everything done while I have it apart. Thanks for the infor.
   / ? About radio install on JD 4520 #8
xrjohndeere,
Did you order the outside mirrors on your cab? Might be just as effective.
I don't believe I did. But that might be a good option to look into. Do you have them on yours and are they helpful? I have had tractors with mirrors in the past but they didn't do much good because of the vibration I couldn't see anything.
   / ? About radio install on JD 4520 #10
No I did not but the 4720 cab at the dealership I looked at did have them. They might be helpful to you, I did not experience any vibration problems when I tested it but don't think a camera would be any less susceptible to vibrations either. With the camera and screen you have two pieces to shake whereas the mirror has only one.
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2017 Ram 4500 Bucket Truck (A51039)
2017 Ram 4500...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
71064 (A49346)
71064 (A49346)
2014 VOLVO VHD DAY CAB (INOPERABLE) (A50854)
2014 VOLVO VHD DAY...
