Brad_Blazer
I designed and built a bucket grapple with some VERY generous help from Larry (Gugliols) in plasma cutting the parts. The design is based on an original one by Rob (3RRL) but scaled up for my Koyler 195 loader. It started with Larry sending the 2-D AutoCad drawings scaled up for me. Then we got into cylinder options and of course I wanted to use the cheapest ASAE cylnder and that screwed everything up - you know it gets complicated trying to optimize with pencil and paper.
I then made up this spreadsheet (employing the law of cosines) so I could quickly try different geometries and even use "goal seek" in the Excel tools to get what I wanted. Here is a version that allows pretty easy entry of dimensions for any type of hydraulic arm. I threw in a graphic to identify the dimensions called out in the spreadsheet. It will predict the tip force and speed through the range of motion and graph them instantly.
To open the spreadsheet you will have to change the file extension from .txt to .xls.
