Does Northern Fool sell a hydro cylinder I can use as a toplink?
   / Does Northern Fool sell a hydro cylinder I can use as a toplink? #1
Slacker
Gold Member
Durham, NC
Farmtrac 360 TLB
I got $100 in gift cards for Northern Fool and I'd love to buy a Hydraulic cylinder to use
as a toplink. I've got remotes already, just need the cylinder and the hoses.
Looking at the website, I can't find any cylinders that have the correct ends.
Anyone know if NT carries what I need (without modification/welding?)
   / Does Northern Fool sell a hydro cylinder I can use as a toplink? #2
If you don't buy hydraulic toplink cylinder then chances are that some modification will be necessary. Your best bet is to find a cylinder that has the the attachments bored through the shaft and the rear of the cylinder.
   / Does Northern Fool sell a hydro cylinder I can use as a toplink? #3
I bought a brand new toplink cylinder off of eBay for $80. I had to add 2 hoses and 2 ISO CUT connectors. One end was a little too wide to fit into the tractor bracket but a die grinder solved that problem...
   / Does Northern Fool sell a hydro cylinder I can use as a toplink? #4
No Northern doesnt sell top link cylinders. I bought mine from Dalton Bearing and Hydralic in Tennesse. They sell cat 1 and cat 2 top links and the price wasnt to bad for the cat 1 but the cat 2 was more expensive. Just another option instead of surplus center... Bull
   / Does Northern Fool sell a hydro cylinder I can use as a toplink? #6
I ran across this link for hydraulic top links. I don't know anything about the company.
Hydraulic Index
Best regards, Steve
Also neat links on Bailey Net and Surplus Center - added them to my where to look list. TNX JJ
   / Does Northern Fool sell a hydro cylinder I can use as a toplink? #7
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
