borg warner hydraulic pump
/ borg warner hydraulic pump #1
smo219
wondering if anyone knows the specs on a borg warner s15s5ah22r pump?
/ borg warner hydraulic pump #3
And good luck contacting them. They have been bought out and are not friendly in giving out specs.
/ borg warner hydraulic pump #4
I have the same pump and number on my gehl 2500 skidsteer.The owners maual says that is compensated 7.25 GPM at 3000 RPM, 2000 PSI capacity. Have you had any luck finding a replacement?
/ borg warner hydraulic pump #5
s= gear pump
15= series number
s=united states
15= gpm
a= ports location (side)
h= mounting pad option (2-bolts)
2= straight, keyed, short drive shaft
2= design number
r = clockwise rotation
/ borg warner hydraulic pump #6
Re: borg warner hydraulic pump
Has anyone found a replacement for their Borg Warner pump? I'm looking for one for my Gehl HL2500A skid steer. Any info would be much appreciated. Thank You.
/ borg warner hydraulic pump #7
Based on the answer above, it is a 7.25 gpm pump at 3000 RPM. There are 231 cubic inches in a gallon so if we take 7.25 gallons times 231 we get a capacity of 1675 cubic inches at 3000 RPM. Then divide 1675 by 3000 RPM and we get a capacity of .56 cubic inches per rev. If you go to the Dynamic Fluid Components website Dynamic Fluid Components, Inc. - F20 Hydraulic Gear Pump you will see that the GP-F20-10 has a capacity of .61 cubic inches/rev, which is close. Add a -P-C to the part number if you want clockwise rotation. These pumps are available online from Northern Tool.This series is SAE A2 standard flange which should match Borg Warner. Please verify all of my info as I am not an expert, I just went through looking for a replay event myself and had to discover this on my own so I wanted to give you a leg up. Dynamic has a PDF catalog page on these pumps that gives you all of the dimensions. Information at Northern is weak.
/ borg warner hydraulic pump #8
garypaper your math is correct. This would also be around a 9 or 10 cc pump if the model code is metric.
/ borg warner hydraulic pump #9
garypaper; Thank you so very much for replying to my question, I appreciate the comeback. I will try to verify your info and check with Northern. Again, thank you.
2012 CARGO CRAFT 24' T/A ENCLOSED TRAILER (A65643)
2012 CARGO CRAFT...
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
