47" Snowblower Chute Rotation Mod -Revisited
   / 47" Snowblower Chute Rotation Mod -Revisited #11
I tried this on my 47' snowblower, and yes it did give me more rotation of the chute, unfortunately I also observed that having the cable wrapped around the smaller pulleys also placed more stress on the center pivot pulley, mine actually loosened up twice, even after I had torqued it up good and tight!:( The center pulley has a lot of stress applied to it when the chute is being turned and I could actually see that it was bending the steel plate that it was mounted too. So before it broke that I removed that setup. It seems that the extra wraps of cables rubbing on each other seem to create undue forces that this blower setup is not designed to handle....Thats my 2 cents worth. So if you do this, keep an eye out for this problem. I would like to have a chute rotator system that does not require cable, guess I would have to redesign the bottom of the chute and find some way to rotate the assembly with the hydraulic cylinder:rolleyes:
It does not take a lot of force to rotate the chute but if you make the cables too tight they work against them selves, if you read my post again you will see that I say to leave some slack.
   / 47" Snowblower Chute Rotation Mod -Revisited #13
perhaps you are right, but I didn't snug up the cable too tightly....and I could still see a lot of stress. Maybe I will try it again on my new 54" blower:) I wonder if you were to replace the small single groove pulley with a double groove pulley of the same diameter, if this would help eleviate some of the cable wear?:confused:
Did you make up new longer cables and run the cable in the pulley and not on the bushing?
   / 47" Snowblower Chute Rotation Mod -Revisited #15
HYDRAULIC CHUTE TURN
this is how I did it
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
Miles,26,126 (A50323)
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
