Lost My NH TC35 Owner's Manual
   / Lost My NH TC35 Owner's Manual #1
Carykong
Gold Member
near Williamsburg ,Virginia
TC 35 New Holland and 52 Case VAC,LT25 Woodmizer logmill
Good evening Tractor Buds, Can anyone look up the 300hr routine maintence requirements for my TC35? Filters?What Fluids?etc.
Have misplace my owner's manual for second time. Purchased replacement manual for $35 a few months ago. Misplaced. Please forward info on 300hr maintence points. Maybe I will find my manual in time for the 400hr check up. Many thanks in advance. Not eager to purchase a third owners manual.
   / Lost My NH TC35 Owner's Manual #2
Cary, I would be happy to look up the chart, but you have an identical one to the manual on the bottom side of your tractor's hood. Just raise the hood and look at the Lube and Maintenance Chart.
EDIT: I'm adding the maintenance interval chart out of my owner's manual, but it is for a HST tractor. Don't worry, the intervals are the same except you don't have a HST filter and don't have HST pedals to lube. Your clutch pedal may also have a zerk fitting somewhere. Otherwise, you should find them very close, just some few things in different spots.
   / Lost My NH TC35 Owner's Manual #3
Cary, I have a manual that you are welcome to but it might be for the DA model. You are welcome to it just pay postage and its yours. Let me know.
Terry,
thank you Jim and Terry for helping hand. I failed to mention that my TC35 is an HST. Looks like its time to replace all hydraulic and tranny fluid and filters. Is the rear reduction gears regular gear 90w oil?
   / Lost My NH TC35 Owner's Manual #5
NO! NO! NO! Use New Holland Multi-G 134C fluid only or its equivalent. There is no 90W oil used anywhere in your tractor. There is only one fluid and one filler cap behind your fuel tank and above the 3PH rockshaft (the cap is yellow and the dipstick is beside it.) The Multi-G 134 fluid is also used in your front axle and drop boxes as well as power steering fluid.
thanks again Jim, I'm on it.
Prior to my 300hr routine maintence,I have relied on the dealer for all my tractor check ups while under warranty. I am spoiled and ignorant on some of the basic features of my tractor. Actually have not looked under the hood to find maintenance schedule,yet. Will advise. Gotta find my owner's manual and really get to know my tractor.
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
