3-Point Hitch Too Much Sway In 3pt. Hitch....
   / Too Much Sway In 3pt. Hitch.... #11
Your Deere can take the punishment. :) Glad you discovered another "adjustment" to make. And I agree with the iMatch for the 3 ph. Easy to set it and forget it. And picking up the ballast box is a dream compared to aligning it on the "bare" arms. :)
   / Too Much Sway In 3pt. Hitch.... #12
Thanks everyone. I'm all set on this now.
Such an important adjustment that I was totally un-aware of. And very simple, I might add.
All set.
Thanks.
Not quite;
GENERALLY ground engaging implements need a bit of freedom to swing.
Maybe 4 inches on Cat 1, 5 or so on Cat 2.
Know that a plow will move left as soon as you lower it (-:
   / Too Much Sway In 3pt. Hitch.... #13
Anyone know where I should look for any damage that might have occured.?? Freakin' 600lb. weight box back there.........
If you don't see anything obvious, then there's nothing to worry about.
JB.
   / Too Much Sway In 3pt. Hitch.... #14
At worse case, you might have some minor scraping of the tire lugs where the lift arms were hitting. It should not have any damage to anything else. I really dont like the turnbuckle design as it is hard to lock them without double wrenching and at least for me, it is quiet a tight squeeze to get my body in around them. I like the sliding bar with pin type but unfortunately on my tractor I also have the turnbuckle type. Mine have a mind to loosen off during use if the lock nut is not really really tight.
   / Too Much Sway In 3pt. Hitch.... #15
Agreed, in fact tire lug bumping is the usual symptom that I actually NOTICE (-:
A less than perfect World, but I sometimes think a ratchet mechanism would be well suited.
At other times I can think of all sorts of reasons why it wouldn't, e.g. loading up with mud, freezing, etc.
Stuck shut or stuck open, either one would be a significant pain.
Turnbuckles; they do offer the FINE adjustment and can bring some force to bear, they also remind me to have TWO big crescent wrenches aboard (-:
One of those rules around tractors; Lock nuts don't exist where they are not needed and don't always exist where it would be very desirable for them to exist.
I looked at the tire and it has no signs of wearing.
I actually like the design of the adjustment. It has cooter pins that lock the adjustment in place...the threads can move about a quarter turn in either direction.
And, I'm a big guy yet I can get to the adjustment with no problems. Takes me about a minute or 2 and I am good go.
   / Too Much Sway In 3pt. Hitch.... #17
My three point adjustment linkage has given me some problems throughout the past year. Mostly everything is too sloppy to adjust the implements tight.
First: I lost a retaining pin when operating my rotary cutter in heavy brush...it went unnoticed....which allowed a shaft (that holds the lower arm) to slide over and bend slightly. I got it re-installed....but it isn't right.
Second: I bought my tractor used....and the previous owner had replaced a chain link with a "will-fit" link. In short.....it fits but not correctly.
The 3 point linkage adjustment is pretty particular about everything fitting correctly. Once bent or sprung a little....its hard for me to make it work correctly.
I am going to do a rebuild with the right parts......if it ever warms up.
   / Too Much Sway In 3pt. Hitch.... #18
Are there any good quality adjusters out there similar to the ones on the 55 series?My 655 has the "standard" 3 point hitch and it's going to cost $120 to replace my left side adjuster.(The previous owner shortened the stud.Then cross threaded it.....all the way tight.Sigh.)
UNUSED PABREAK RT260 - 72" HYD TILLER (A57193)
UNUSED PABREAK...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A57193)
UNUSED RAYTREE...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
500 Gallon Fuel Tank with Pump (A55852)
500 Gallon Fuel...
CFG Industrial MX15RX (A56469)
CFG Industrial...
2019 John Deere 550K Crawler Tractor Dozer (A55851)
2019 John Deere...
