Differential rear lock
   / Differential rear lock #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
when the differential rear is locked can the front be engaged in 4/wd ?
   / Differential rear lock #3
Yes, just don't engage the lock if the rear wheels are spinning.
   / Differential rear lock #4
The 4wd engagement simply locks the front driveshaft to the same rotational speed as the rear axle pinion assembly.
The Diff Lock simply locks the two rear axle shafts to the same rotational speed.
Neither interferes with the engagement of the other.
Warning, when the Diff Lock is engaged the tractor will not want to turn. With both rear axle shafts locked at the same speed it will only want to go straight. That's why the Diff Lock is spring loaded and requires constant input from the operator to stay locked which is a safety procedure to help prevent the turning problem.
I frequently use the 4wd and Diff Lock at the same time. Provides you with true 3wd drive. True 4wd can only be achieved if your front differential has a locking device. I don't know of any tractors that do.
   / Differential rear lock #5
The M7040, M8540, and M9540 all have an automatic front locking differential (limited slip). It was one motivation for purchasing the M7040 recently.
I have been in true 4WD only on a couple of occasions but it works just like you might imagine. Four R1s gripping the ground with 70HP is impressive. It is not like a big ag tractor but is plenty enough to do anything on a small plot.
   / Differential rear lock #6
yes it can, just remember to disengage before turning on hard surfaces
   / Differential rear lock #7
I didn't know that gw, thanks for the info.
I'm a Jeep freak and frequently use a mechanical locker in the front axle. The multiplication effect of that added traction is amazing. Must be used wisely as you can bust front axle components by a simple blip of the throttle!!! :eek:
   / Differential rear lock #8
Huh, I thought that it was ok to do that - at a reasonable speed - so that it engages easier and you then gain traction. I'm wrong on that?
   / Differential rear lock #9
I also thought this was OK - within reason. The only way I can get things to align properly for the lock to engage is to let the slipping wheel spin slowly while putting a little pressure on the locking pedal. I wouldn't just jam it down while the wheels are spinning quickly but otherwise...
   / Differential rear lock #10
wuh oh :eek:...how can I tell if I did any damage to it by doing just that.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
