Tree Shear, fixed blade
   / Tree Shear, fixed blade #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
New and interesting tree shear. Uses the force of the machine to push a "V"type blade through the tree. No moving parts. Will cut on the go.
YouTube - vcutter video# 1
YouTube - vcutter2
The system finally let me post this.
   / Tree Shear, fixed blade #2
Wow JJ! Never seen anything like that. So simple. One thing...it looks like you would need to go slow with a CUT and not ram...so as not to mess up your loader arms/cylinders.
   / Tree Shear, fixed blade #3
Watch out for falling limbs and tree tops. That shear of that design looks like a machine or man destroyer. Must have full enclosed and guarded rops for operator and full guarding for tractor/skid-steer using something like that. Speed wouldn't matter with a limb impaled in hood of tractor or operators head:eek:
I don't think it was designed for big stuff, probably no more than 4 to 5 in green tree. Should be fairly easy to build one.
   / Tree Shear, fixed blade #5
The beginning of the video looks like the machine takes some pretty serious ramming hits to get those trees down. And I wouldn't even consider trying this out without a full FOPS cage. My ROPS wouldn't be near enough protection to even consider it.
Also, what about hitting a 4" tree with *almsost* enough force to sheer it off? Could you get the blades stuck and not have enough traction to back out of it?
   / Tree Shear, fixed blade #7
Wow JJ
That is one of the most dangerous attachments I have seen in a long time.:eek:
Sure does cut through those big DEAD trees fast though.;)
Not sure how it would fair out with a large green tree though.
Thanks for the link, it was amusing.
   / Tree Shear, fixed blade #9
I like the grab and pull back feature for waters edge! ... Otherwise its all medium to HD bushog work, For my money Id take the versatility of the bushog to do this and other clearing functions well. ... A grabbing shear for waters edge tho is an excellent idea seed. Ill put it on my project list.
larry
   / Tree Shear, fixed blade #10
Yeah, most of the stuff they were taking down in the video could be done with a bush hog or flail mower. I'd be a little concerned about ramming into larger trees with the FEL on a CUT for fear of damaging the FEL arms. Skid Steers and bulldozer arms are tougher than those on our CUTs. This thing depends on momentum and mass to cut which requires ramming and that is not what tractor FELs are designed to do.
ExMark Quest Zero Turn Mower (A50860)
ExMark Quest Zero...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2016 Ford Escape SUV (A48082)
2016 Ford Escape...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
