Snow Snow blower that clogs up the chute
   / Snow blower that clogs up the chute #1
EARLYSTANGS
I have a brand new kobota L3400 36hp tractor and purchased a very lightly used George White 74" rear mount blower. The problem that I'm having is that the chute is constantly getting cloged up with snow. Just wondering if anyone has an ideas as to why.
   / Snow blower that clogs up the chute #2
Do you have the throttle pulled down as far it will go??????
   / Snow blower that clogs up the chute #3
It also depends on the snow at times. If the weather gets mild it will melt the top few inches of snow a little. It will create wet snow on the top of cold powdery snow. That is about the only thing that renders my snowblower useless. The two kind of snow get mixed up and stick/freeze to the blower auger. I never had the chute clogged up.
   / Snow blower that clogs up the chute #4
If you are not operating at 540 rpm for the rear pto you will always have problems.
If you are traveling too fast in reverse with a throttle setting that is not providing 540 rpm you will have trouble.
Using some wd 40 or fluid film to coat the spout will help throw the snow further.
If you buy a clarence impeller kit it will improve the throwing ability of the snow blower fan.
I have a link for the impeller kit on the forum here and clarence has a web page.
google clarence small engines. :)
leon
   / Snow blower that clogs up the chute #6
Welcome to the Forum.
Where are you located? And what type of snow (dry, wet) are you blowing (or trying to blow)?
   / Snow blower that clogs up the chute #8
Coat it with Fluid Flim.
   / Snow blower that clogs up the chute #9
I've also heard the kitchen spray called PAM also helps, just don't let your better half see you taking the spray can. :D
   / Snow blower that clogs up the chute #10
I use Pam, Wd-40, and/or silicone spray. But sometimes, it just depends on the snow. When it's really wet and sticky, keeping the PTO speed high is also important. I removed the basket thingy on the front of the chute to clear clogs when they do happen. Stop the blower and turn off the tractor before attempting to clear a clog.
UNUSED FUTURE CW59-59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE...
CFG Industrial MH12RX (A56469)
CFG Industrial...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
