Lesson Learned on being nice
/ Lesson Learned on being nice #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
Well we finally got a good snow so I thought I would be nice and snow blow a path for my wife to dump the manure for her horses. Well she spent thousands of dollars last summer on a contractor to make her a riding ring. So after he tore up a whole acre of pasture and screwed up the swale I had to drain the area he presumably regraded it all to drain better. That is why there was standing water out there again this fall and everywhere he backfilled was literally about 1-2' deep mud. Well I thought since it had been in the teens for several days that it would be frozen, my mistake. So the shortest way to the manure pile is across this area. I started out with my Gravely snow blower and once I realized my problem it was too late. With almost no ground clearance It was buried to the axles in no time. Ok so get the Farmtrac out and pull it out. Needless to say it is now next too the Gravely half way up to the axles in mud and not going anywhere. I think they are destined to live there until mid summer when it will hopefully dry out a little. I have a feeling I will be lucky if the handles of the gravely are still sticking out of the mud by then and the Farmtrac isn't lower than than the axles. I have a friend with an 85hp JD that is about 6 miles away. This summer we may be able to drive it over and use about 50' of chain to keep it on dry ground and pull the other two out. Thanks for letting me rant.
Eric
/ Lesson Learned on being nice #2
Dude that sux!! Like the ole saying...."Nice guys finish last"!!
Good luck to ya man!
/ Lesson Learned on being nice #3
Sorry to hear you are stuck. Can you get the guy who caused the mess to pull you out, on his dime? Since he created your quagmire the least he can do is get you out of it. Waiting till spring may be an option but not a good one for your equipment ,which I'm sure you will need to use before spring?!
Push back !:mad:
/ Lesson Learned on being nice #4
Eric, are you sure it's right to blame a guy that did some grading for you for your bog-land?
Jake
/ Lesson Learned on being nice #5
Why would you want leave your equipment sitting buried in mud and wait until spring ?
Grab a length or 2 of chain and get hold of a 4x4 truck, can your friend with the big JD come help you now ? Heck call a wrecker if thats what it is going to take.
/ Lesson Learned on being nice #6
Mark, it doesn't take a wrecker to get a snow-blower out of the mud.
/ Lesson Learned on being nice #7
Jake
Probably not right, but it sounds like he did a much less than expected job of it, and it feels good to rant on people that did you wrong, whether it is exactly 'fair' or not. :) :)
Without the snow there now, the cold snap we are getting should freeze the ground out that way now. I would try real hard to get the wheels free of being trapped in mud, and you should be able to tow them out - or even walk the loader tractor out on it's own - as the ground freezes up here.
Snow is a good insulator, while we have had minus 30 degrees the past 2 days, I'm not at all worried about the pipes or ground freezing very deep, because we have had close to 2 feet of snow first, keeping the deep frost out of the ground. Other years when it is only down to zero, without snow that frost can go 3-4 feet deep in a hurry.
--->Paul
/ Lesson Learned on being nice #8
Well, I think you should get your snow shoes on and walk out there and put a rope or something on the equipment so you can find it next spring when it is sunk below the mud.;)
/ Lesson Learned on being nice #9
While he may have messed up the swale, I'd not blame him for the mud. If the area is wet, it's gonna take some time for that new ground to compact and stabilize enough to hold up equipment, I'd say a year unless you get some serious grass-matt to take hold.
Ditto on the snow being a good ground insulator. We've been COLD here for a month, below freezing during the day and 0 at night. yet, while cleaning up the storm today I still had to be careful not to peel up unfrozen sod.
So, add a layer of insulating snow on top of the huge reservoir of heat the earth holds, and the mud will stay, well, mud, for quite some time unless there are some extreme low temps for long periods of time. That's why the ground heaves and water mains freeze on cold snowless winters vs. winters with early, heavy, snowfall.
Anyway, no way would I leave my equipment out to sit until spring. I'd dig and blast if I had to. Let it sit there for long, and blasting will be the answer. The ground you've peeled the snow from is going to freeze quickly.
/ Lesson Learned on being nice #10
I believe i would get my equipment out of there,;) if you don't your going to be having Horse dung piling up on one side of the other while blocking this so called path to the disposal area,:D and then what you going to have to dig out of :eek:
/ Lesson Learned on being nice #11
Time to get out there with some shovels and dig around the wheels a bit. Then jam some logs or rock down to give you some traction.. Next put them horses to work besides making manure. Hook em up start up the tractor and drive that thing on out of there.
/ Lesson Learned on being nice #12
All this good advise, and still no one has asked for pics.:confused:
there's another good thread on here asking for pis of worst stuck. sounds like you have a good one.:D
Thanks for the suggestions. It started snowing before the ground froze. It has been snowing for about 1.5 days now and is getting about 1-2' now. It is light and dry since the temp is in the teens. The Farmtrac is not too deep yet. One back wheel is almost to the axle so I decided to stop before I made things worse. They are also stuck out in the middle of an old farm field about 150' from the closest tree. The old thoroughbred mare would look at me with a real stupid look if I tried to hook her up. The pony on the other hand might actually try pulling. With the depth of the snow I am not sure I could get a 4x4 back there. I did remember a new neighbor has a tractor about the size of mine a couple doors down. I will try tracking him down this week.
I am still a little bitter about the wife spending so much on this ring. I thought there should have been more discussion and she thought she had discussed it. The guy did what she asked I just didn't think it needed to be such a big project. This was also the second time in two years I took a trip out of town only to find dirt moved where I didn't want it. So is i right to blame him? Probably not but he isn't around and I was pissed for getting both of them stuck trying to do something nice and I needed to rant.
/ Lesson Learned on being nice #15
No **** Sherlock !
I was being facetious. :)
But since you opened this door. There is also a tractor that is stuck. If the equipment were mine I would do whatever I had to to retrieve them out of the mud. Even if that meant calling a Wrecker !
/ Lesson Learned on being nice #16
dig around the tires and shovel the snow off the ground so it can freeze, then pull them out. As for something to pull against, drive a stake in the ground for a come-along to hook to.
Not to sound unappreciative for the suggestion but that stake will either hit rock at about 6"-12" or go into sand with water at 2.5'. Glaciers do weird things.
I will try a shovel and some hay tomorrow. Hopefully I can creep it out.
/ Lesson Learned on being nice #18
My mechanic got a Ryder Truck stuck in a field about 300' from the road. It was the big one that was a cab over with a lift gate. He called me for help. I simply loaded up every length of chain and tow strap I had. I then went to every neighbor ect and borrowed every chain I could get. Used my F-150 to pull it out by putting it on the road and pulling 20' then taking a link out. Only took 30 minutes to get it out.
Chris
/ Lesson Learned on being nice #20
Chris
So Diamondpilot............ How much does 300 ft. of chain weigh? you really had a workout that day lending your helping hand didn't ya! :D Good guy alert
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A60352)
2006 Ford F-750...
2014 PETERBILT 367 6X4 TRI/A  SLEEPER TRUCK TRACTOR (A59908)
2014 PETERBILT 367...
