1966 cub cadet 123 motor rebuild
   / 1966 cub cadet 123 motor rebuild #12
holy smokes. im not sure, but i would think hed be better off finding a donor and having it rebuilt.
   / 1966 cub cadet 123 motor rebuild #13
overmyhead. Where are you located. I may have your solution if you are close enough.
Where did you find that kohler?? I looked all over that web page and found nothing. It says that they don't have any in stock, does that seem to imply this is a rebuilt one or a knock off? Does anyone know how long ago they stopped making these? I thought it was a long time ago.
I am located in Vermont, Ludlow to be precise. I bought this tractor to move snow around the driveway. Not as the primary plower but to clean up after the plow. I bought it for $350 this summer. It took a while but I had it running really well, or at least I thought....
I hadn't really put it to use until the first storm and I had always checked the oil. First day using it to plow I checked the oil and it was exactly where it had been. So the next I skipped that. Big mistake I guess. I noe know that the first thing that I should have done when I got it home was to do an oil change. I have never really been into small engines before and most that I have are new so these issues are less frequent. There is a cub over in NH with a front loader on it it is a very similar machine. I have been thinking about purchasing that and then using mine for parts.
while I have been looking into what to do I decided to learn a few things from all this. The first lesson I already learned, check the oil!!!! I have started tearing down the motor. I have never seen the inside of a motor before so I thought since I have nothing to loose.....
When I got the head off the top of the piston had a bit of oily residue on it but the area around the piston and the lifters was really full of carbon deposites. Is this normal for an engine this old or does this show that something was going wrong before I bought it. I have kept everything that I have removed so far, although since I wasn't thinking I would need to put it back together I haven't recorded every nut and bolt I have removed.
On the back of the engine there are a few parts that connect to the drive shaft. I removed the one that had the slot in it to recieve the pin in the end of the shaft. There is a nut inside that holds on the part that part was connected to. I think I will need some of these parts no matter what I do but I can't get the nut off because the engine turns with it. Any ideas? I have the manual for the K301 in .pdf form but it doesn't cover this as it really isn't part of the motor. I also can't get off the front pto. And I don't know how to.
Will
Another question, does anyone know what model #s have the narrow frame? Since I want to plow with whatever I get, and I already have the plow for the 123 I would need another narrow frame.
Thanks
Will
Thanks dex3361. I had seen that list before but never realy looked at the frame size.
What about buying a new/used block? There are 2 on ebay right now. Both are less than $10 dollars and look, on the outside, to be in about the same shape as the one I have now. How hard would it be to put my stuff on onther K301 block? I opened the bottom of my block already and took a look. There isn't too much in there. Of course what do I know? I guess the most critical part is getting the timing right so the lifters and piston work correctly. Is that very hard? Then I could get the rebuild kit for @$80 dollars and I would be off and running again for less than $100. Sounds good and I love a challenge. If I didn't I wouldn't have bought a 50 year old tractor!
well a new motor has been purchased. I got a Techumsa 11 hp coming from Small engine warehouse. Strangely enough when I first got the tractor I went to their site and saw this motor but at the time I was thinking it wasn't what I wanted. But here we are and it was well priced and has a kit to fit this model. Just hope it is a good engine......
   / 1966 cub cadet 123 motor rebuild #20
Be aware that tecumseh when out of business a year ago. as a dealer i was having problems getting parts 30 days after the stop of production. all parts available are limited to distributor stock and dealer shelves
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A57453)
2007 Isuzu FTR...
Metal Mailbox (A57454)
MASSAGE CHAIR (A58214)
12ft. S/A Utility Trailer (A56859)
12ft. S/A Utility...
Stout Brush Grapple (A59814)
Stout Brush...
1991 Snowco Trailer (A59814)
1991 Snowco...
