Loading hay (pics)
/ Loading hay (pics) #21
Hey D7E
Do you get two cuttings in usually up there? I'm in Syracuse and my hay man usually gets in 2 cuttings, sometimes 3. Just curious what your growing seasons like a little further north?
Usually 3 cuts but the 3rd did'nt get done this year as combining and tillage was very late so there was'nt time to do everything and the hay got ignored a little.
It does look like a fresh clear day out.:D
What size and weight would those bales be?:D
Notice the Radiator covers on the Trucks?:D
Egon...they are 8ft bales and the few i weighed are just over 800lbs
/ Loading hay (pics) #25
D7...What kind of hay is that??? Alfalfa??? and where is it going? I thought it would be heavier than that. Only about 30,000 on truck.
It was going to winsconsin through a dealer..
/ Loading hay (pics) #30
If you look real close at the pics you can see the tops of the alfalfa sticking up thru the snow.
Money in the bank... rolling out of those fields! ;)
I used to sit in haystacks hunting coyotes at those temps. Now, if it was +90F at that time; you'd have to call 911 for me... wouldna made it off the stack!
Heated truck - heated tractor. The only time it's nippy is when you strap the bales down. I'd do it for $175-$225/ton.
Thanks for sharin' - D7E.
AKfish
/ Loading hay (pics) #31
I have never fed big squares. They look convenient vs rounds. Other than stacking and shipping, is there any other advantage? Nice pics, that's a lot of hay there!
Re clothing:
1 undershirt of moisture wicking fabric
2 sweatshirt type top
3. insulated coveralls or snowsuit
(same layers for the legs and lower half, 2 pairs of socks, good gloves and boots and a balaclava and hat)
That's enough to well below -40. Any more and you'd sweat and then you are messed up. We overnight camped at -43 once. It was pretty toasty inside 2 good sleeping bags but I don't think I'd do it again.
/ Loading hay (pics) #32
Bales break into chunks/slices just like little squares.
Better leaf retention.
Easier to handle with small tractors/skidloaders.
We only do square for sale to the states.The rounds sell better up here and i think we prefer to make rounds as machinery is cheaper and you don't have the performance of stacking and tarping,Hay needs to be dryer to go into squares too.
/ Loading hay (pics) #34
-18 F as I type this. Thank God there is no wind. to **** cold to do anything outside but feed the horse's and come back in. :(
/ Loading hay (pics) #35
We've fed both small squares and round to the horses as availability dictated, they seem to much prefer the small squares for some reason known only to them, and we have a lot less waste. Some people here make the big squares, I hadn't realized they were the same as small only much bigger (individual flakes, etc.)
Rounds are a pain for horse feed, you need a turntable to unroll them easily.
Chilly
3 more loads went today,But the last one ......Only just..!
/ Loading hay (pics) #37
I have gone to using the large squares for our horses. Putting up hay takes me about 30 minutes per cutting of driving tractor and I'm done. At 50+ tossing hay all day long is not nearly as fun as it used to be.
/ Loading hay (pics) #38
Either that driver wasn't looking in his mirror or if he did he gave a big OH S**T. Looks like there was plenty of room to make a wide turn.
2025 48in Drum Mulcher Skid Steer Attachment (A61572)
2025 48in Drum...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2017 TOYOTA CAMRY SEDAN (A59912)
2017 TOYOTA CAMRY...
Informational Lot - Shipping (A63689)
Informational Lot...
