1966 cub cadet 123 motor rebuild
   / 1966 cub cadet 123 motor rebuild #1
over my head
This summer I purchased a 1966 cub cadet model 123 for $350. Did some work on it this fall getting it ready for winter. On the first big snow I blew the motor. My fault, the oil was low and it ran down faster than I thought it would. Yes I had checked it several times but this was the first time I was putting the tractor to real work since getting it. The rod didn't go through the engine so I am considering rebuilding it. It still turns.
My first question is do you think it is a good idea to attempt this? I have some mechanical ability and am interested in the project. I have already started but could be convinced to use a mechanic if that would be the right thing to do.
Second question would be should I just repower? It is more expensive and my fear is that I will get a less well made engine that will not be as good as what I have. I have looked a Kohler and B&S as possible sources for new engines. Price seems to be in the $1500-1800 range.
Also is this model considered a narrrow frame?
never mind, motor is cracked behind the starter. Going to need a new one. Any advise on a good engine to repower with?:mad:
   / 1966 cub cadet 123 motor rebuild #3
the cheapest thing to do would be to find a similar donor and just run it. otherwise, theres a few websites that discuss repowering in pretty good depth
   / 1966 cub cadet 123 motor rebuild #4
Purchase another mower and sell the parts from the one you have now. If memory serves the Cub 123 had a Kohler K301 engine. You will think you have purchased shares in a gold mine when buying a replacement Kohler K301 cast iron engine.
Checked out prices and it seems that I would have to repower with something else as the K301 is no longer made. Found a guy on ebay that had one remanufactured for pulling. He wanted @ $650. Then someone in email suggested a vangurd 18 hp but didn't say the make.
would a K321 work as a replacement? It's a 14 hp. Aside from the dipstick being moved it looks almost identical
   / 1966 cub cadet 123 motor rebuild #7
I have a friend that has a brand new k321 never ran complete with starter he wants 1200.00 or best offer.
   / 1966 cub cadet 123 motor rebuild #8
I repowered my 129 Cub Cadet with a 16 HP kohler Kseries but it has to have been configured for a Cub they have a different oil pan and I think the PTO shaft is different. Where are you located?
I am in vermont. A few places on the net have engine blocks for sale, would need a lot of parts off my current one.
Will
   / 1966 cub cadet 123 motor rebuild #10
Over my head....be careful when selecting a different Kohler engine.....some of them are not made to fit in the narrow frame....
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
yellow ball Trailer (A56859)
yellow ball...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
