Loose joystick - HELP !
   / Loose joystick - HELP ! #11
Sorry Kevin. I never took any photos of it when I took it apart. It's pretty straight forward though so you should have no problems. Good luck.
   / Loose joystick - HELP ! #12
Yup, I concur, Jam nut. I had this issue on ck30, on delivery during demo of features. Service guy showed up next a.m. and had fixed in 15 minutes(wish I'd watched that!). Occured again on me two months ago. I tried first to remove boot from above(carefully) was able to loosen three sides, last one too tight. Even with three sides loose not enough movement of boot up to get at jam nut. So..... I removed two bolts that secure the joy stick valve body under user platform(did not remove anything from top of user platform, i.e. seat, 3pt, nothing). After removing bolts, dropped valve body down enough to remove boot(1/4"), pushed boot up on joy stick, positioned stick where desired, tightened jam nut, then re-assembled. Good to go. It is a bit of a PITA, wish the boot could be removed from above w/o disassembling anything, but alas, no.
I wish someone would've mentioned the blue locktite before now..... ;) That would have been useful two months ago, but something tells me I'll have another opportunity. Good luck Kevin. We're getting the white stuff here too. At least we'll be getting into double digit temps today.:)
   / Loose joystick - HELP ! #13
IH3444 said:
Same jam nut came loose several times on my NH TC48, I finally completely remove the threaded control lever, cleaned everything with carb cleaner, and then reassembled with "blue" locktite. Problem cured. I had tighten the jam nut several times, but it kept working loose. Now it's fixed, and can be removed if necessary. The block it screws into is aluminum, wish it had been a low grade of stainless steel, say a 304 alloy. May have added $2 to the cost of the tractor. All these manufactures look for cost cutting measures.
Did the same to mine and worked great...was able to move to a more comfortable angle so I am glad it happened.
Bruce
   / Loose joystick - HELP ! #14
Hey Guys,
This morning while removing a few inches of snow with my CK20 FEL (49 hours) the joystick came loose. Fortunately I was able to finish the driveway with my 3 pt. snowblower (kind of handy having both front & rear capability). Except for the cold temp it was an easy fit. Took off plastic trim, removed boot, screwed in joystick, tightened jam nut, reassembled. Wish I had looked at the posts here first so I would have reassembled with Locktight.
My question is how does the joystick become unscrewed? I can not believe it has rotated that much in use. What am I missing here? And if it turns why does it not turn as much clockwise as counter clockwise??
HA704
   / Loose joystick - HELP ! #15
If you can still use it its most likley jam nut. Quick fix take finger and squezz boot and hand tighten jam nut, have lever 180%,1/2 turn off, facing back, with jam hand tight turn joy clockwise and you might be lucky and tighten that away. might save time
I know this is probably a dead thread but I have to leave a comment and hopefully someone else searching will find this suggestion.
I had the Kioti loose FEL joystick problem although the float is working. It had turned about 180 so I had trouble operating it while moving snow. I went out prepared for a big, cold disassembly project but decided to try your advice first. Five minutes later I was back inside with the joystick where it belongs.
Thanks for the great, simple suggestion!
Resourceful site insn't it. Kudos to TBN and all who support this site, I know i appreciate the information here. I think it is great that we can look for solutions to problems with only a click away. Thank you !
I hope everyone has a happy and safe Tractoring New Year.
Kevin
   / Loose joystick - HELP ! #17
I may or may not have a similar issue here - so I want to ask if similar circumstances preceded the various repairs noted here. I'm on a DK40SE sled too BTW.
I jumped off the wrong side and got the joystick for the FEL caught in the coat and bent the heck out of it. Seems to still want to work although it is jacked so that I can't make out which way is up and down or left right anymore.
Anyone else damage theirs with a run in like this or similar? I'm trying to guage whether I have a fix like described or I'm in for more serious repair.
Also I bought the shop manual for the tractor and it doesnt say much about the remote for the FEL portions of the valve body. If I buy the FEL's shop book can I assume it will have more detail about the remote control for it? It's a KL401 kioti loader... I really don't want to buy the full shop manual for such a simple attachment - but if I have to I will. Just wondering if anyone has it and can confirm details about the remote being in it.
Thanks - new to using Kioti and new to this forum - looks to be an awesome source of information.
chris
   / Loose joystick - HELP ! #18
No it will not be in the 401 loader manual it is part of the tractor..
Generally what happens is the ball pops out of the socket. It usually will still work but like you said it is not in the correct position.
You will need a new cinematic kit.
It will set you back $29.65 plus shipping
If you look between # 2 & 4 you will see 3 round rods with little balls on them, this is what pops out and it will distort the housing enough that it will never be right again.
   / Loose joystick - HELP ! #19
Thanks! That's a great diagram - I will pore over the manual again and see if it specifically covers my flavor.
   / Loose joystick - HELP ! #20
Well, joy stick on my CK30 is loose. Still works, thank goodness. I will give these ideas a try, starting with this one
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
207010 (A55853)
207010 (A55853)
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
