Tractor Snowmobile Combo circa 1929
/ Tractor Snowmobile Combo circa 1929 #2
My Grandad had a set of half tracks for his 8N, that's how they would go to town in the winter when the roads were drifted too much for the one ton grain truck. They were only 8 miles out so not too bad a trip.
/ Tractor Snowmobile Combo circa 1929 #3
/ Tractor Snowmobile Combo circa 1929 #4
Thats cool. Now why dont they make them any more?
/ Tractor Snowmobile Combo circa 1929 #7
Much to my surprise, I actually ran into one of these at the The Heidrick Ag History Center & Antique Tractor Museum in Woodland, CA. See below:
The video has been on TBN several times, It's very cool but some may be "burnt out" from seeing it so many times before, that's why there's not more replies than you'd expect from such an interesting machine.
Seeing an actual picture of it is pretty interesting, seeing it close up.
Wonder if it floats on water :)
/ Tractor Snowmobile Combo circa 1929 #9
Seeing as how snow isn't usually as dense as water,it may just float.I don't have enough info to do flotation calculations.
/ Tractor Snowmobile Combo circa 1929 #10
/ Tractor Snowmobile Combo circa 1929 #11
Yes I too have seen this unit before and have asked the same question. WHY did it not sell like hotcakes,...it seems like a magnificent idea. Not just for snow but anywhere,....even be great on desert sand and swampy areas etc.
It is a great idea to "begin" with and could be lowered slightly for better COG and various changes and adaptations could be a wondrous machine. Doesn't have to be expensive and could be made just as safe as any other "thing".
I'd love to have one here in the country! Oh well,....what else ya got?
Merry Christmas!
CHEERS!
. . tug
/ Tractor Snowmobile Combo circa 1929 #12
The Russians also tried this design for one of their military vehicles. I suspect these didn't catch on is due to the rigid nature of the screws. They can't adapt to changes in terrain the way tracks can. A track system can follow the terrain more readily than a rigid screw can. With the screw, it's possible to get just a small contact point on the ground with the rest of the screw eating air. This is what I noticed on the Russian vehicle when they were driving it on solid to marsh ground.
However I still think this is an extremely interesting design concept that unfortunately didn't pan out.
/ Tractor Snowmobile Combo circa 1929 #13
Here's the link to the Russian machine:
YouTube - ?ross-country vehicle ZIL-29061
But tracks do ride better:
YouTube - extreme offroad from Russia.PART 2
/ Tractor Snowmobile Combo circa 1929 #14
Pretty cool, I agree not as practical as tracks for all around use but I bet there are some environments that the screws would do better.
I like how they turned the screws in the same direction and allowed the machine to travel perpendicular to it's normal travel path (sideways).
/ Tractor Snowmobile Combo circa 1929 #15
I saw a video on Utube about a team who used this design to try to make an artic crossing from Alaska to Russa.
/ Tractor Snowmobile Combo circa 1929 #16
Haymaker:
Thanks for finding and posting the Russian videos. Another thought I had concerning the screws is that the flights would be subjected to extreme wear, especially if they are made of garden variety steel.
A friend of mine at the renewable energy lab I used to work at has an experimental wood chip fueled heating plant that is giving them all sorts of grief. The plan is to use bark beetle killed trees as a fuel source; but the mineral content in the chips is causing clinkers that are chewing up the flights of the ash pit augers the boiler manufacturer insisted on using.
/ Tractor Snowmobile Combo circa 1929 #19
Not ENTIRELY abandoned; see mecanum wheels.
(approximate spelling, but a search should find it).
The point contact problem would probably go away with low pressure pneumatic cylinders/rollers and a thick fat rubber screw thread.
With modern control systems the power distribution for direction changes could bring handling down to steering wheel and stop/go pedal, or fwd/stop/reverse.
As easy to handle as a hydro tractor ? Yeah, probably.
/ Tractor Snowmobile Combo circa 1929 #20
Haymaker:
I pull a lot of augers from a Domtar paper pulp mill to be rebuilt. It's amazing what clinkers, and even wood chips, will do to these in time. I thought the same thing, especially if operated in a rocky area. Does Russia have rocks? I thought it was nothing but snow and mud!:)
3PT FENCE ROW SPRAYER (A63291)
3PT FENCE ROW...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2015 John Deere X320 Lawn Mower (A63116)
2015 John Deere...
2017 International HX620 Quint Dump (A62613)
2017 International...
2008 GALYEAN 120 BBL ACID TRAILER (A63569)
2008 GALYEAN 120...
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
