At Home In The Woods
   / At Home In The Woods #231
It seams to me that if the wire is hard to pull up it would be impossible to push it down. The gravel will spread when you pull the wire up because it is unconstrained on top. As the wire comes up the gravel will fill in. The gravel will not spread as easily when you push down because is constrained by the ground.
I think it will be just fine.
Russ
BINGO!!!!!
Wire is easier to pull up than force back down in the concrete.
   / At Home In The Woods #232
I totally agree whit ruralruss
@brin
Yes I was all alone at the poor , I dead the slab in 2 section the section is 30 x 36 m dine 15 X 36 one shoot , is not easy bu is double . I didn't have time for a helicopter or better say the strength to do it . I want to build everything alone , I have the time and I can watch TV so better build a house :rolleyes:
This is haw is at the present time , all covered whit 6 mil plastic I will reopen the site in the spring when I have to poor more concrete for the garage , here is few more pictures and I am sorry Obed i am posting hear .
   / At Home In The Woods #233
razvy,
That looks like an awesome project you have going on.
Start a new thread and keep the pics coming!:)
   / At Home In The Woods #234
thx .
It's a idea , maybe in the late spring after I reopen the project, until then I have to deal whit this boring season:rolleyes:
razvy,
I'm very impressed with your project. Thanks for posting the pictures. Did you build the forms for the poured walls yourself?
Obed
Obed - Did you put down a plastic vapor barrier before they poured your slab ? I hope so since that control moisure which can lead to mold and it may prevent radon as well but it sure does reduce dampness in the structure.
Yes, under the main floor garage slab and under the basement slab. The vapor barrier under the garage slab was not required by code unless the garage is heated. We put a barrier under the garage just in case I want to heat it. We do plan on insulating the garage.
Obed
Eddie,
There is rebar in the walls running horizontally and vertically.
Obed.
Monday evening under the lights the concrete workers finished all the flatwork other than cutting the stress joints. The last thing done Monday night was to seal the concrete. One of the workers was out there in his sock feet rolling the seal on the concrete with a roller.
Tuesday the stess joints were cut. The joints are approximately 10 feet apart. In the garage they are approximately 8 feet apart. Joints were cut at all the interior corners because concrete cracking is very prone at these spots.
   / At Home In The Woods #239
Obed, the flatwork looks very good from here. Must be a great feeling to have that in place. You get to stop staring at a hole in the ground :) I don't see j-bolts. What's the plan for those?
Did they use screed bars for the troweling?
Dave.
Wednesday the framing began.
17101 (A55851)
17101 (A55851)
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2025 GPS GTT7167K 16ft T/A Utility Trailer (A56859)
2025 GPS GTT7167K...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
2006 Fiori Dump Articulated Dump Truck (A57453)
2006 Fiori Dump...
