Hyd for a Floor Jack
/ Hyd for a Floor Jack #1
DougM
Gold Member
Northeast Ohio
GC 2310
I have two 3 ton floor jacks and both are leaking.
Seems to be around the pump pin on the handle
any ideas please.
Thanks
/ Hyd for a Floor Jack #2
new oring?
gear oil?
soundguy
So no one has ever rebuilt a floor jack ???
/ Hyd for a Floor Jack #5
Not worth it. I hate to say it but its like a TV, not worth fixing. Just throw it away and get a new on unless its a $.25 part.
I had a nice 2.5 ton Napa Floor Jack that would leak down. The kit to rebuild it from Napa was $75. I picked up a new 3.5 ton at Sams Club with rapid up for $59 back in 2000 and use it about 3 times a week or more and its not missed a beat.
Same thing with a 6 ton Napa Bottle Jack I had. I just got a new one at Harbor Freight 6-7 years ago for $19.99 on sale and tossed the old one.
It worth more as scrap metal. Sorry to say that but thats the facts!
The only other suggestion I have that may slow it down but not stop it is at Lowes or Home Deopt they make a Teflon product in rope form. You could get some 1/16" material or so, it comes on little cards in 3' lengths or so, and remove the nut compressing the plunger o-ring and give it a couple wraps. You put it near the o-ring and when you put the compression nut back down it squishes out and seals. Its in the plumbing dept.
Chris
/ Hyd for a Floor Jack #6
DougM,
I've used power steering leak stop on inexpensive hydraulic systems.
It has something in it to cause o-rings, seals etc. to swell stopping the leak. Sometimes it takes a month or so to do its job. Worth a try?
I have not had the b***s to use it on expensive systems. Just stuff I was going to haul to the dump because replacment was cheaper than fixing.
/ Hyd for a Floor Jack #7
Not to get off the subject, but I have used the sealer type PS fluid in my Ford 2000. I belive it was Prestone brand. It was just something to try to get by, until I had time to tear in to it. I filled it up, and ran for about 4 or 5 hours that day. Decided to power wash it off when I finished. Not sure what's in that stuff, but it hasn't leaked since. And that's been about 8 years ago... The only time I've had to add, was when I installed the Aux. transmission in '03, then to replace the clutch last winter, and lost fluid when I split the tractor.
But I'd try the O-ring and packing first.
The only thing I've had rebuilt were my trusty old Walker, and Hein-Werner brand bottle jacks, and that's been over 20 years ago, and they were old when I bought them at auctions.
/ Hyd for a Floor Jack #8
I had a craftsman jack that was leaking, the o rings inside were not normal, couldent get replacements- so I bought a replacement for 100. with 2 jack stands; and for the heck of it I asked the sears repair shop the cost of a new pump assy on my new jack.. about 150.00. Go figure....
NEW Wolverine 78" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 78"...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2010 FORD F750 BUCKET TRUCK (A63276)
2010 FORD F750...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
