Need fleet of equipment for new operation
   / Need fleet of equipment for new operation #31
how many acres?
Get your cows. Get a barn cleaner, get a cheap spreader.
Hire someone or get the hay made on halves.
Machinery does not make you money. The cows do. Concentrate on them.
Why on earth are you shorting yourself in the barn where the money is made?
You'll end up hating life and cows in general and then the dissatisfaction sets in...get a barn cleaner.
   / Need fleet of equipment for new operation #32
how many acres?
Good advice but lately even the cows don't make you money:(
   / Need fleet of equipment for new operation #33
ahh...looking at 14 headed to 16 or so....
Might have a chance to make a few bucks.
Get your cattle bought now before the price starts its climb
Well I will be using a herd first strategy but in order to feed that herd I'll need machinery. The other farmers around me are too busy with their own stuff to provide my crops as well. There also isn't any crop farmers in my area :(
I have also run into problems with the barn. Apparently it's in worse condition that originally anticipated. one of the main beams in the hay loft is broke in half, the roof needs to be replaced as it leaks and the concrete floor and foundation are breaking up. Dad had estimates done, all are in the $15,000 range. I don't know jack about repairing buildings so I can't do it myself. So now I'm in the process of looking for a barn and land to rent so my debt is still controlled (although not as much as I like).
   / Need fleet of equipment for new operation #35
You haven't said how many acres you have. Or how many cows you intend to milk. Or how much help you have.
In your position I would....
Forget about another tractor.
Look for decent older stuff to get the hay in if I couldn't talk a neighbor into doing it on halves.
Find a cheap small spreader.
A 170 is plenty of tractor to get a lot of stuff done. A 7' or 9' haybine, rake and something like a JD24T won't set you back too far. Heck you can still make hay with a sickle mower and crimper and an old high wheel rake if you need to.
Start raising heifer calves. You can build your own hutches for a decent price. Get a load of gravel hauled in to put em on, pick up calves at the local sales barn if nothing else. Get em early spring so they can hit the pasture hard all summer. Depending on how many you have, buying hay the first winter may be something to look at. Sell em as bigger heifers next year if the price is right and have a little jack to work with.....
Get some fence made, get that beam jacked up and replaced, get some quotes on a roof.
Any way you go, it's not gonna be a free ride. Spend the money to get your place fixed up, then you're not at the mercy of a landlord.
I see a lot of negativity in your posts. Have you actually talked to any of your neighbors about your plans? Asked around to see if anyone was interested in making your hay? You said the place was seeded down, how does the hay get made now?
I have a buddy in about the same spot. His neighbors are quite helpful if he needs a hand once in a while. Which is good because his milk check is pretty much spoken for. A loan for 20 cows plus the money to keep the place running adds up
   / Need fleet of equipment for new operation #36
if you can afford it, i would definetly buy a new baler no mater if it is round or square. That is one thing most people can't afford to be broke down or always working on. i would deffinetly go with New Holland hay equipment as far as the cutters and balers. New Holland started hay equipment first back in the early 1900 and still are number one. Over 700,000 square balers sold and nearly 300,000 round balers......can't go wrong there
   / Need fleet of equipment for new operation #37
Can anybody give me the basic differences between these balers?
JD
24T
214T
336
346
NH
273
310
315
320
Also, is there any performance difference between a bar rake, a rotary rake and a wheel rake?
We had 2x 346 deere balers from new and both of them were a nightmare mechanically and failed to get the knotters right even after replacing them...I prefer a NH baler or as is the most popular here an inline IH.
   / Need fleet of equipment for new operation #38
Didn't/doesn't Deere and NH have the same knotter?
Now if you want the best haybaler you would get a Massey Ferguson.:)
Never heard that before......everybody around my area has told me JD for square baler
378721 (A54865)
378721 (A54865)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2023 CATERPILLAR 262D3 SKID STEER (A60429)
2023 CATERPILLAR...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
