Ford 4000 air in hydraulics?
   / Ford 4000 air in hydraulics? #1
swilk
Member
Southern Indiana
Kioti DK5010HS
I am going to look at a 1962 Ford 4000 tomorrow ..... I have come to the conclusion I cannot afford the tractor I "want" right now so I am looking to buy something to get me by a few years.
Anyway, the guy tells me the hydraulics work great unless you let the tractor sit for a long period of time (months) and then you have to "loosen a screw and some air will come out ... then they work fine again".
This sound like a common problem with these tractors? Easily fixed? Enough reason to walk away from the tractor?
here is the ad:
Ford 4000 1962, Rebuilt motor, decent paint, 60% rubber, 47hp, rare tractor, live power, runs great, looks good, with bush hog no power steering $2000.
   / Ford 4000 air in hydraulics? #2
I think that most tractors will have a little air in the system some where. If it is throughout the system, it is probably coming from a suction leak. Replace or tighten the hose. If the air is in the cyl, raise and lower the FEL several times, the air should be purged.
   / Ford 4000 air in hydraulics? #3
here is the ad:
The hydraulic pump is located above the static level of the oil in the reservoir. The pump's shaft seal is leaking, allowing air in and the oil to drain back into the reservoir. The tractor needs a pump rebuild and if the seal land on the pump driveshaft is scored, a shaft replacement. Not a big deal if you have the time and talent, or access to someone who does. In my market, the tractor would be a fair deal even with this flaw if the tractor was properly represented in the ad.
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
John Deere A Tractor (A50514)
John Deere A...
TRUCKING INFO (A50775)
2012 John Deere 410K (A47384)
2012 John Deere...
2014 TOYOTA 8FGCU25 FORKLIFT (A51222)
2014 TOYOTA...
