septic tank
/ septic tank #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Hi we are on a septic tank and i have been having some water back up into the basment floor drain. When ever we flush a toilet there is a burp or bubbles comeing up and then some water backs into the basement.
Its been 7 years since we had it pumped out.
Is it a vent issue(vent clogged on roof) or
a full septic?
/ septic tank #2
a full septic?
I would vote for calling the honeydew truck asap. I'm not sure a clogged vent could cause a backup to that extent. Can you access your septic tank lids and eyeball the situation? Even removing the lid would provide air if the vent stack is blocked. Make sure it isn't just a clogged waste line too. Do you have a clean-out in your basement?
Dave.
/ septic tank #3
Another possibility is that the main drain line from the house to the septic tank is partially obstructed. Last year we had the same thing ( water backing up into the basement). The main drain pipe had broken and was partially obstructed by TP, etc catching on the broken portions of pipe. Had to have the pipe replaced from under the basment slab to the tank. Very expensive $$$$. Hope your problem is something simpler than that. If pumping doesn't fix it sewer companies can do a visual inspection with a camera to check the integrity of the drain lines.
/ septic tank #4
It could be either but if the septic is full it could be because of a field problem. Find the lids, pull them off and look.If the level of the tank is above the outflow it is a field problem. Get it pumped anyway to stop the problem in the interim of fixing the field. It may be as simple as something partially plugging the outflow pipe.
If it is a plugged vent then a flushing toilet is likely to clear nearby traps and you will get a sewer smell back through the sink. I jury rig a shop vac into the inspection port of my main drain and turn it on blow to clear my vent which occasionaly freezes shut from condensation in winter. Either way its a dirty job but someone has to do it:eek:
/ septic tank
thanks....I will call for a truck and then dig the lid out, its nice and cold today, i will also get a snake and check for clogs.
/ septic tank #6
One observation, normally septic systems are to high to allow for basement floor drain. you must have a walk out basement or a yard that quickly drops off away from house, also normally wouldn't want a floor drain connected to septic system for the reason you are experiencing, that is the lowest open port and that's where it would overflow first.
Could be a number of things already mentioned, my vote is partly blocked baffle out of the tank, which a good cleaning should clear.
If it is just a slow draining tank, then without that floor drain you may never of noticed it because it would catch up after some period of time.
Does the water that comes up in that drain go back down fairly quickly? Describe the topography around the house and yard, again with a floor drain it could be indicative of a low pitched main line which would be susceptible to backing up with any restriction in flow.
Worst case would be a corrupted field.
/ septic tank #7
Hello neighbor. :) Notice these things never happen in June? You wouldn't have one of those wonderful sand mounds would you? I'm expecting to have a problem in the next month or two with mine, it's been a couple winters since my last issue.
/ septic tank
Walk out basement with a gentle sloping yard away from the house.
the water that comes out of the drain goes back down but takes a while.
I was hoping to get the tank pumped out in june but this is the month for things to go...
replaced the water heater, will be repacing the well pressure pump, and apparently getting the septic pumped. Cant wait for december to be over.
just called roto-rooter they will be up tommorrow before noon to pump it out. ~250 for a 1k gallon tank.
/ septic tank #9
ForgeBlast,
Ah! the joys of a septic tank. 5 yrs ago I moved to a home with a Septic Tank system(600 gallon). My first. Called the old timer in the business whom regularly took care of the system I purchased.
My home was built in the 40's. Same Septic Tank system is in place. He told me to 1; keep the kitchen grease IN the garbage can, not the drain 2: only tp in the drain, no other paper including those sanitary towels women use for wiping down the toilet etc. they are not bio degradeable in the septic system. (my neighbors wife PLUGGED their system with those towels) 3: Pump your tank every 3 years, that will keep your drain field from plugging with solids, drain fields are expensive to replace compared to pumping a tank. 4: Get single acting yeast from your local bakery and put in the tank 2 times a year (1# yeast + 1 cup sugar in warm 100deg water, wait 10 min to activate yeast and flush) 4: NEVER PUT THOSE STORE BOUGHT SEPTIC TANK PRODUCTS IN YOUR SEPTIC TANKS SYSTEM.
Your system is probably blocked at the inlet. Best to pump the tanks and check it out. Call an old timer whom has been in the business for years. If you live in a cold climate, install extensions on the tank. That way you don't have to dig in frozen dirt to check or clean the tank.
Best of luck. Hope it is a simple fix. Dave
/ septic tank
Thanks, I grew up on a septic and watched my dad clog his up with kitchen grease. I keep it in the garbage especially after seeing the bill.
I do a lot of home brewing and my yeast once im done with it goes down the drain to keep the system working.
I was worried i was going to have to dig the lid up but i do have an extension close to the house, will the truck be able to pump from there its i think 4'' pvc pipe.
We also since we are on a well, have high effecience toilets and a great washer to keep the tank and well happy.
I am hoping its a simple fix, after the rest of the stuff going this month i need to catch a break.
/ septic tank #11
If your septic tank has filters they may need checking.
Lets just hope it's something simple that can be rectified for little cost.:D
/ septic tank #13
forgeblast, The 4" pvc is an inspection port for the drain field. Looking in the pipe will tell you if the drain field is plugged. There will be standing water in it if it is plugged.
The tank should be between the inspection port and the cleanout located near the house. In your case the cleanout might be in the basement on the same side of the house where the inspection pipe is located. Maybe you have a pumping system to pump the waste up to the tank. Don't know all the details. Your tank cleaning person should give you some insight. $250 is a fair price for pumping. Finding the tank and digging up the lid will cost a bit more. Dave
/ septic tank #14
If you are on a hill and the tank has an open to air drain, check for an ice block. I just had to clear my garage drain to the outside, that has my condensate from my new furnace ran to it.
/ septic tank
i know right where the lid is and tommorrow hope to dig it out to save me a bit of cash. i will have to do some poking around tommorrow morning....today i have to get home bundle the kid up and go to pick up the well pressure tank and get the snake. then hopfully find out whats wrong....love when problems like this happen in the winter.
/ septic tank #16
I've never seen or heard of a septic tank having a filter... Think about that for a minute. The function of a septic tank simply doesn't have use for a filter... solid stuff goes into the tank, settles out and decomposes...
Find the clean out plugs.. there should be a couple of them between the house and the septic tank.. flush and watch for water flowing down the pipe.. if it's clogged, the water won't flow or will exit the clean out plug... Good luck with it..
/ septic tank #17
You'll be able to tell alot once you open it, with a garden hose you will quickly establish if it's plugged going in or blocked going out.
First of all the level should be aprx 12 inches from the top, if it's filled right to the top then the out going pipe/baffle is blocked. Run the water in the tank first, if the level doesn't rise above the static level then it's the main line coming in that's causing the trouble. If it fills up then its either the baffle or the field. but most likely the baffle.
Make sure they don't just pump it out without checking the inlet and outlet. Around here Roto Rooter wouldn't be the best choice, being a franchise you usually get the least experienced personnel and they will always try and sell you some other expensive service. but your local may be legit.
Good luck.
/ septic tank #18
I just had my 800 gallon pumped this fall @$150. Local guy who showed me what to check for and made sure that things were as they should be prior to and after pumping.As JB4310 said you really need to open it and look, especially if you have not in 7 years -- if it is a simple two compartment with a leach field type system then you can usually see the problem when you take off both caps. Gets a little more complex when you have peat or other filtration, macerators etc but does not sound like that is the case here. Just some thoughts:eek:
/ septic tank #19
As far as filters, there may be a difference of label. Some of the newer tanks have a filter / baffle system that can plug up. The local septic supplier around here sells a service option to come and clean them on a set schedule.
/ septic tank #20
2011 CATERPILLAR TH337AG TELESCOPIC FORKLIFT (A64279)
2011 CATERPILLAR...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
2022 John Deere 410R Sprayer (A63111)
2022 John Deere...
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
CATERPILLAR D5K2...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
