V-Snowplow Blade & CUT, Workable?
/ V-Snowplow Blade & CUT, Workable? #1
TBDonnelly
In the palm of Michigan's Lower Peninsula
Kioti CK30HST, KL130 FEL, turf tires
Is a front mounted 6 foot V-plow workable (weight wise and hydraulic wise) on a Kioti CK30 HST with loader valve. From what I'm told it's a self contained system that requires a battery hook up. Is it doable to hook the hydraulics up through the tractor loader valve? Figuring the plow would be tractor frame mounted. The plow had a previous life mounted on a Ford Ranger pickup.
Don
/ V-Snowplow Blade & CUT, Workable? #2
You would need at least 3 hydraulic circuits to operate a V-plow. The loader valve only has two. But yes, it is doable...
Thanks Kenny, I've been (still) searching past threads. I'm told it's a complete workable system. Is the only issue using it as-is, the size of the alternator on the tractor?
Don
/ V-Snowplow Blade & CUT, Workable? #4
Powering it from your tractors electrical system could be problematic for sure. Plow's usually draw a lot of current.
Possibly a compromise might be to use the tractors hydraulics to do the lifting but retain the electric part for the angling...I would need more specifics about the plow and your machine to offer more detailed suggestions though.
Back to the drawing board. 'Sold' today before I got to see it(was just posted yesterday evening). I thought it sounded like a good deal. 'Tis the season here. Although this big storm passing through went just North of us, all we got was a dusting of snow.
Don
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
