Snow snow blade on bx1860
/ snow blade on bx1860 #1
nolan1
Member
Does anybody know if a snowblade from an L series tractor will fit a bx 1860. I cant seem to find any info on this anywhere.
It is a 5ft model l2172a I am going to purchase a quick hitch but not sure if this plow will fit and I cant find a picture of the quick hitch anywhere. I found a good deal on this plow so I was hoping I could make it work. Thank you for the quick reply.
/ snow blade on bx1860 #4
Here is a picture courtesy of Killer_B of the quick hitch used on both the BX series, and the B series. The Quick Hitch is slightly different in the tractor mounting dimensions between the two, but the part that attaches to the front implements is the same.
/ snow blade on bx1860 #5
Here's some photo's for you. The first two are from a BX1500 I believe. I saved them to help with my modification. I have the 54" light duty blade that I converted to 4-way hydraulics from manual angle. No idea if the L blade will fit this quick hitch. Hope the pic's are helpful.
Thank you very much!
Thank you that helps me out a lot!
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
Evinrude Johnson 3x13.75x13 Aluminum Marine Motor Propeller (A66734)
Evinrude Johnson...
2021 CHEVROLET SILVERADO 3500HD SERVOCE TRUCK (A67714)
2021 CHEVROLET...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2011 BRENNER TANK 200BBL CRUDE TANKER (A67714)
2011 BRENNER TANK...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
