Will power steer pump work for FEL?
/ Will power steer pump work for FEL? #1
chvojka
I have a small john deer 110 and want a FEL would a power steering pump from mabey a truck work? only looking to lift 300lbs. or so.
/ Will power steer pump work for FEL? #2
You can probably get the pressure but not sufficient flow. I would think it'd be slow.
M.D.
/ Will power steer pump work for FEL? #3
A power steering pump should work fine. Years ago I built a hydraulic wrecker(tow truck) boom for the back of my pick up and T'd into my truck's exsisting pump. It had lots of power. I also built a hydraulic bender, run with an electric motor, using an old power steering pump. That machine had a large cylinder and it worked great also. You will probably need to make a bigger oil reservoir though.
/ Will power steer pump work for FEL? #4
I have a Power-Trac, that uses a 3000 psi, 3 GPM pump, that runs off the fan belt. It takes about 6 HP to operate the pump. It supplies enough power to steer the PT, and provide lift and tilt. It can lift 1200 lbs. These little pump run about $125, and a joystick valve for about $199.
How much HP do you have to work with?
I have 8hp kohler could I hook it shaft to shaft? or belt it?
/ Will power steer pump work for FEL? #6
Either way will work if the engine is not being used for anything else. This is the pump that I have. If you hook it directly, shaft to shaft, the pump will have to turn opposite the shaft on the engine, since the shaft direction is determined by looking at the shaft. . If you use a belt, you can manipulate it to work, such as turning in the same direction.
https://www.surpluscenter.com/item.asp?UID=2009120718425093&item=9-4199&catname=hydraulic
/ Will power steer pump work for FEL? #7
Also keep in mind that lift power is depermined not only by pump pressure capablity, but piston size.. more size.. more lift.. however.. more size=more volume needed, or it gets slow.
soundguy
/ Will power steer pump work for FEL? #8
You can use a PS pump, I have also seen them off a 2 ton truck like an F700 or a C65 Chevy. One aff a Nissan tuck or a Jeep with a remote tan on it is really nice. You may also have to take the regulator off the pump if its pump mounted. I have left them on for some applications. It just gives a steady ouput nomater the revolutions of the motor. I ve used one to run a small lift o na sears tractor and a small blade angle on a Cub tractor.
/ Will power steer pump work for FEL? #9
That was my suggestion,a 1 or 2 ton truck unit.I would add a cooler on the return side and possibly add on to the sheet metal resivior for more compacity.
/ Will power steer pump work for FEL? #10
For a lawn tractor, this pump will be fine. To not overload your front axle you need small diameter cylinders anyways, which dont require a big flow. Pressure of most powersteering units is about 120 bar, not really that much but again, you dont need much force to lift 300 pounds.
/ Will power steer pump work for FEL? #11
Most 1 tons are the same as a half ton, My 72 F600 has a larger tank on it with a return tube coiled around the tank for cooling. My 95 F700 has a pretty good tank to. For more capacity take a larger tank and braze a fitting to it to met the return on the other tank or adapt it to the lid of the pump res. Just run the return line to the bigger tank first.
/ Will power steer pump work for FEL? #12
2017 TOYOTA CAMRY SEDAN (A59912)
2017 TOYOTA CAMRY...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2006 Ford E-450 (A64119)
2006 Ford E-450...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
