is this a pump or a motor?
/ is this a pump or a motor? #1
NBstunter
new brunswick canada
2006 kubota L2800
found it in my grand fathers barn as he said anything in it is mine. if its a motor [thanks kennyd] i could use it for my snow blower shoot. thanks
/ is this a pump or a motor? #2
if its a pump i could use it for my snow blower shoot. thanks
Do you mean "if it's a motor I can..."?
Looks like a small motor because the ports are the same size. Pumps usually have on port larger (the return or suction) than the other.
yes i ment motor sorry. on a motor does it work to put power to one side to make it go one way and power to the other side to make it go the other way?
/ is this a pump or a motor? #4
Yes, Correct.
International Harvester (IH) 130 Manure Spreader (A66408)
International...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
(5) John Deere Front Tractor Weights (A65640)
(5) John Deere...
New/Unused ATS 60 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 60...
