Backhoe Mahindra 4510 and Woods 750 backhoe
   / Mahindra 4510 and Woods 750 backhoe #1
yanmars
I have a 4wd Mahindra 4510 cab tractor. I also have a Woods/Bush Hog 750 3pt hitch backhoe. Will this fit on my tractor and do I need a subframe or will the Woods 3 pt hitch arms handle the same. I think the tractor is about 45 horsepower, Category 1. Thanks
   / Mahindra 4510 and Woods 750 backhoe #2
The backhoe will fit on your 3PH, but if the tractor is still under warranty, Mahindra will void the warranty. If you mount this backhoe on the tractor and use it, also use your head. If something won't move, work at it a little at a time or leave it there. Or if it won't move and you keep banging on it, that is when you will break your tractor. I hope you understand what I am saying and good luck.
Thank you for the information. Also does anyone know the part number for the appropriate subframe for the 750 Woods backhoe and Mahindra 4510 tractor?
   / Mahindra 4510 and Woods 750 backhoe #4
It is the top link that is not designed to take the stress of the BH might exert on it. My dealer informed me that if the BH rips it out of the housing it would not be covered by warranty. The rest of the tractor will still be covered. I saw somewhere on TBN a way replacing the top link by an attachment tying it to the frame or rear axle.
   / Mahindra 4510 and Woods 750 backhoe #5
I am not so sure that is correct about the warranty. The top link attachment to the tractor is the most vulnerable stress point, but that can be relieved by a chain from the top link mount on the backhoe to the tractor rear axil on both sides and a strong binder to tighten it. If you do that and use your head when operating the backhoe you should be in good shape.
Redneck: My barn is about 1/2 mile from both roads, hard even to see so I must live in the country.
I am pleased about this site and the posters. Alot of quick and good information from all. I will have more questions in the future. Thanks again all.
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A52128)
2018 Ram 5500...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2006 International 4400 LP Ambulance (A50323)
2006 International...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
