CK 30 stiff 4WD shifter
/ CK 30 stiff 4WD shifter #1
Wattsfurniture
Tiger, Georgia USA
Kioti CK30
My 3 year old ck30 manual has always had a super stiff 4WD shiftewr...had to stand on it.
Finally the knob is getting worn and I need a stronger threaded insert.
Anyone have this problem? Happen to know what thread size it is ? (metric I think)
I've got some late season core aerating to do and can't shift the thing into 4WD.
Also need it to grind leaves...running a rear discharge finish mower with the tractor in reverse works great for this...just makes them vanish into powder. But need 4WD for traction in reverse.
Les
/ CK 30 stiff 4WD shifter #2
I had similar issues with the 4wd on my CK30. There is some external linkage between the lever and the gearbox. I lubed it all up well and after a few engage/disengagements... it has never worked smoother/easier.
/ CK 30 stiff 4WD shifter #3
IXLR8 is correct. Lots of lubricant on all the moving parts. Once you've worked it several times when well lubed the rust will wear smooth and it will work much easier.
/ CK 30 stiff 4WD shifter #4
Ixlr8 and Deon both found the trick as I have. My 4wd shifter was very stiff when new. I used spray white lithium grease on all the linkage for the shifter. Make sure you also lube where the shaft goes into the tranny case on the left side. Mine isn't as easy as changing gears but it will shift into 4wd with just a little pressure. Sometimes I'll move forward or back slightly and it will drop it. Mine is an hst and the same goes for the range selector.
/ CK 30 stiff 4WD shifter #5
Yea, mine was that bad that I finally broke the knob off. once I got the knob back on I went under the tractor and tapped on the linkage with hammer and then hit it with some wd40 and other lube. Works great now. I think you are gonna have to do the same. You will hear the difference in sound when you tap it and it finally loosens up.
aloha
joe
ps..you can get the knob back on with a little epoxy glue and a screw hose clamp.
/ CK 30 stiff 4WD shifter #6
Once all the linkage is lubed.........Turn the steering wheel all the way to the left, rub your palms together, then engage the 4 wheel drive. Repeat to disengage. Let us know if this works.
Don
/ CK 30 stiff 4WD shifter #7
Me too. There is a cam-like linkage underneath the left side. Lube every thing, especially that linkage and once you get if free, work it back and forth a few times. Every once in a while I work mine back in forth and re-lube just to keep it in good working order.
I pushed my knob off as well. But, was able to thread it back on. That part could stand an upgrade. Nice knob and all, but shouldn't be able to break it off so easily. I've actually thought about replacing it with an old-fashioned phenolic type with a real metal insert. Just not sure of the bolt size/thread pitch.
/ CK 30 stiff 4WD shifter #8
Depends on if the problem is stiff linkage or is a case of the gears not lined up between spline shafts. I used to have a very difficult time getting it to shift. There isn't anything like a syncronizer on the gears, so you won't be able to shift unless the teeth of the front drive shaft are lined up with the mating teeth of the sleeve from the rear (I think it's a sleeve type, but the principle is the same regardless). I always had trouble until I changed the way I shifted. For years now, I don't push the clutch in, but rather (with the front wheels straight) I apply firm but not excessive pressure on the shift lever and gently tap the HST pedal forward and back. It usually slips in immediately. Shifting out of 4wd is the same but since the teeth are generally under some pressure I have to rock it gently back and froth a couple of inches (the tractor, not the lever) several times before it slides out.
Wow, thanks for all the replies.
I'm about to go out and fire it up, but have to find a way to shift it. Perhaps a vicelock or something. Really must have 4WD for that aerator. I have 1000+ lbs of weights on it.
The plastic insert in the knob is completely buggered. I measured the thread and it seems to be M10x1.25 (I think) and I don't have a tap that size. I'll have to get one to make a stronger metal insert, or cut it on the lathe.
Les
/ CK 30 stiff 4WD shifter #10
Never had to do this on my manual tranny. Goes in and out just about anywhere, under any condition (so far).
New knob with metal insert is cheap: McMaster-Carr
/ CK 30 stiff 4WD shifter #11
Were the shift shaft goes through the transmission case in the key. Make sure you lubicate the shaft at the case. This is true for anywhere a shaft goes through the case, but is most noticeable on the 4wd shifter because there isn't a lot of mechanical advantage in the linkage, and doesn't get used as often.
Lube right at the case and work the shaft. It will free up nicely.
/ CK 30 stiff 4WD shifter #12
For years now, I don't push the clutch in, but rather (with the front wheels straight) I apply firm but not excessive pressure on the shift lever and gently tap the HST pedal forward and back. It usually slips in immediately. Shifting out of 4wd is the same but since the teeth are generally under some pressure I have to rock it gently back and froth a couple of inches (the tractor, not the lever) several times before it slides out.[/QUOTE]
ERE,
You have the method perfected. That is what I have always done. If your think about moving gears, spines or shifting dogs into place you need to align them first or you will be stressing all related parts for no good reason and something will bend or break. Clutch pedal up, light pressure on shifter or 4x4 lever and slight movements of the HST pedal fore and aft. When the parts align they will fit together. Same deal to disengage. If parts are well lubed, this method will always work.
/ CK 30 stiff 4WD shifter #13
the leverage of that short shaft should be addressed. I have to stand on it to put my CK30 into 4WD and I have to use a pry bar to take it out of 4WD. I have followed the lube suggestions none of which have cured the problem. The owner should be able to shift in and out of 4wd with little effort. That is not the case with my CK30HST. My next tractor purchase will compare this pain in the *** feature with what else is available. This design flaw is a very big deal.
/ CK 30 stiff 4WD shifter #14
I don't ever remember taking mine out of FWD. I'm never on the pavement and rarely on the driveway except to plow snow in the winter. I must check mine for movement.
Steve
/ CK 30 stiff 4WD shifter #16
Did that Saturday and it slid right out of FWD and then right back in. Did it a couple of times and it was as free as a bird. Surprised the heck out of me.
Steve
/ CK 30 stiff 4WD shifter #17
A tip I picked up here on TBN is to turn the wheel all the way to the left. Apparently this lines up the gears. If mine doesn't slide in easily I turn the wheel all the way to the left and it slides right into FWD, every time. Has anyone else tried this and is it working for you?
Don
/ CK 30 stiff 4WD shifter #18
If you have a FEL take the weight off the front wheel and it might suprise you how well it works.
Takes all the bind out of the driveline which might help.
Just a thought.
/ CK 30 stiff 4WD shifter #19
Don
I tried this today and it was way easier to shift, good tip.
/ CK 30 stiff 4WD shifter #20
Thanks for posting your findings. (Turning the steering wheel all the way to the left to more easily engage FWD).
That's three of us (Albmn10, you & I) that I know of that have had success with this method.
Maybe more will check in with their findings........
Don
Here are some similar links:
