Does a 2210 have a brass washer on drain plug?
   / Does a 2210 have a brass washer on drain plug? #1
dieselram
Gold Member
Meadville, PA
2007 John Deere 3120 TLBM
My 2210 is now leaking around the drain plug I think, I just changed the oil and now there is a puddle on the floor. The plug fell in the oil pan so I don't know if there was a washer on it before it fell.
   / Does a 2210 have a brass washer on drain plug? #2
I have a 2305 and I'm almost certain that I have a aluminum washer, on mine. I think you have found your problem.
   / Does a 2210 have a brass washer on drain plug? #3
JDParts shows a washer. Part # M806438.
   / Does a 2210 have a brass washer on drain plug? #4
My 4010 has a brass washer. It looks like one that comes with the Puralator or MB oil filters. They usually provide 2. I may have put on one from a filter package, but it may have come with it. I don't recall.
It's interesting that the 4010 (and likely 2210 and other JD diesel engines) uses the same 17 mm plugs for the engine drain and vent on the thermostat as my old 240D had.
Ralph
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
PREVIEW DATES AND TIMES (A54865)
PREVIEW DATES AND...
1998 CATERPILLAR 953C CRAWLER LOADER (A52705)
1998 CATERPILLAR...
2015 Ford F-150 Ext. Cab Pickup Truck (A55788)
2015 Ford F-150...
