Price for stump grinding?
   / Price for stump grinding? #11
Tdog said:
I have ~~ 28 stumps that I want to get ground. They are all sizes, from 4" diameter to a couple of feet. Some are laid over from Katrina in 2005 with some of the rootball exposed.
Has anyone hired a stumpgrinder recently? Just curious. I know I won't get the $7 a pop price that I had 15 years ago for about twice that many stumps.
Thanks,
Jack
I had a guy come out two years ago to grind out three stumps in my yard. He charged me $80.00. A few years back I had a guy come out with a dozer to clear about 1/4 acre for about $75.00 per hour. It took him less than an hour to clear out trees and stumps. I cleaned the rest up with my tractor ( a little Kubota B6000 at the time). Unless you don't want to disturb the surounding area, I would consider a small dozer.
Just my $0.02....
   / Price for stump grinding? #12
I recently had a bunch of them removed for what turned out to be just less than $5 per stump. The guy had a Bobcat and that thing was just flat amazing on a stump. The prices may surprise you because of the huge improvement in technology from years ago with tools like the Bobcat.
I have a small dozer, and honestly, there is no way, absolutely no way I could have removed those stumps with my own equipment in any time frame that would have been acceptable...not to mention equipment repairs.
The guy I hired would work by the hour or by the stump and in my case, it was much better to work by the hour because I had enough for about 2 days of work. The set up time kills you if you have only a small number of stumps.
Check it out, it may not be as bad as you think.
Meadowlarkponds
Where are you in East Texas? I'm near Greenville and was wondering if I could get the name of the guy that you used with the Bobcat?
Thanks
   / Price for stump grinding? #13
Get some C4 and people will pay YOU to come and blow your stumps up:D
   / Price for stump grinding? #14
Guy I work with just had 600 medium to large stumps ground out, cost him 5K. 100 miles NW of Houston
   / Price for stump grinding? #15
I am in Northeast, LA and I charge a minimum of $75. If you have 10 or more average size stumps I charge $15 a piece. If you have a whole lot like some of you are saying I would charge by the job. It would be a lot less than $15 a stump. Also blow overs cost more because they take longer and are harder on the equipment when you start getting loose pieces.
   / Price for stump grinding? #16
Thanks,
Jack
im sending this quote in hopes of picking up more work in your area i generally
charge $1 an inch trees that have been blown over are quite a bit more work.
I'm honest and reliable,would like to touch base with you on this work. Billy 501-442-5885
   / Price for stump grinding? #17
Man, those are cheap prices for grinding. I think I paid $2 per inch 10 years ago.
Just remember there will still be roots left underground, so grinding may not be the best solution depending on what you want to do with the ground.
For large stumps the best answer may be to pull them out with an excavator. It is always more effective and does a better job than a dozer. Faster, less ground disturbance and it can bury the stump in place, if that's what you want.
   / Price for stump grinding? #18
around here, bid on one oak stump (18") was $100 to $200. And they still wouldn't bother coming out and I ended up doing it myself :(
   / Price for stump grinding? #19
Depending on the size of the stumps and what you are wanting to do with the land, a skid steer mulcher might be a good choice. I just had 10 acres of 3yr cutover cleared. $150/hr and about 1/2 acre per hour with stumps, mostly pine with some hardwood down in the bottom, every few feet. It now looks like somebody spread bags of mulch all over it.
   / Price for stump grinding? #20
I spent $540 for a half day of stump grinding a month ago.
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
Blue Diamond 103709 (A53317)
Blue Diamond...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
John Deere 5100M (A53317)
John Deere 5100M...
