ASV RC100 Troubleshooting Question
/ ASV RC100 Troubleshooting Question #1
Diamond Ridge
Was running my machine just around the yard with the bucket on tonight. I had got out of the machine for a minute and when I got back in the machine would not move. I played around with the lap bar a bit and noticed that the turtle light for my speed wasn't on. So I decided to shut the machine down to see if it would just reset itself. Now the machine doesn't want to start but the turtle light is on now before trying to start. All there is now is a clicking noise when trying to start it and the machine had originally started up fine before all of this went down. Any troubleshooting tips would be much appreciated!
/ ASV RC100 Troubleshooting Question #2
Did you lock the pins back after you put your bucket on? There is a lapbar saftey switch, a door saftey switch and the quick attach lock pins. If all those are good and made your battery is dead. ASV will maintain a charge but are not good at charging a weak battery.
See if that helps and welcome aboard!!!!
/ ASV RC100 Troubleshooting Question #3
check the ground under the battery under the cab and if thats it put another nut on the stud
/ ASV RC100 Troubleshooting Question #4
Yes I agree, ASV will operate down to a voltage of 9volts then the saftey solenoids will stop working, The lap bar and seat switch will not keep it from starting. If it has a quick attach switch for the bucket it will prevent it from starting as will the low and high flow switches! Check the battery voltage 1st!!
/ ASV RC100 Troubleshooting Question #5
Shut my machine down for a minute, when I started it again it would not respond to any commands on the joysticks and the light is out on the low range indicator
/ ASV RC100 Troubleshooting Question #6
Your symptoms closely match what i have experienced on an rc100 with a bad alternator. Battery would run down and eventually electronics wouldn't work correctly. Charge your battery and see if it fixes it
2018 Trail King Lowboy (A63689)
2018 Trail King...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
Harlo HP6500 (A60462)
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
2022 EZ-GO ELITE...
