Oh well, at least the day started good
   / Oh well, at least the day started good #21
When taking the wheel/tire off my '99 even if I have done so recently, I have to beat on the tire sidewall with a hammer to dislodge the wheel. About the time I'm good and mad
it comes off.
   / Oh well, at least the day started good #22
I have gotten lucky on my 02 F250 around getting the wheels off. Since they are a hub pilot, I went ahead and cleaned up the hub and then put a light coat of anti-seize on the hub before I put the wheel back on. Knock on wood - no more problems...
FWIW - FaC
FWIW - FaC
I hope to never have to touch them again. My tire guy rotates them for free for buying my tires from him. I just had to deal with this one myself on the side of the road with limited tools.
That is a good idea thoug about the anti-seize. I have never had to touch the tires on our 02 F-250 as my tire guy has done all the tire changes and rotations and we have never had a flat (knock on wood). I will ask him about this though since I never knew these tires were such a pain in the butt to get off the hub.
   / Oh well, at least the day started good #24
Have any of you used "tire slime"? do you recomend it? I have a friend who uses it in almost everything and claims it is great stuff and will fix almost anything.:confused:
I have no experience with it. Do you have any idea how much would be need for this application?:eek:
Nice one Steve.... :rolleyes: I think you could get that fixed with tire slime and a couple of garbage bags -- just bag the tire and rim and fill 'er up!! :D
AKfish
   / Oh well, at least the day started good #25
What my guy did was when he got the tire repaired, he had the shop remove the other 3 wheels to make sure he could get them off later. Might be an idea for future removals.
Whenever I get a new vehicle, I take all the lug nuts off, one at a time, put a little bit of anti-seize on the stud threads, and torque them back on. This takes less than an hour, and I know I will never have to fight a stuck one a midnight in a snowstorm.
Now it looks like it is going to be take each wheel off one at a time. I will still use the anti-seize on the lugs.
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
(8) Ten Hole 23 Inch Steel Rims (A57454)
(8) Ten Hole 23...
Kivel Quick Hitch Skid Steer Attachment (A56860)
Kivel Quick Hitch...
LIGHT TOWER (A56857)
