Baling green hay
/ Baling green hay #1
Kfbeal
Gold Member
South Texas
2005 JD 5103
We cut about 20 acres of Alicia Bermuda grass yesterday only to find out they have upped the rain chanced for Friday to 80%. Reckon it would hurt to bale it late this evening? We've had cool temps but some wind to help dry it out. I checked this morning and about 50% of it's green.
Any suggestions? Wait to see if it rains tomorrow? Or bale it late this evening?
/ Baling green hay #2
If moisture level is above 20% it will spoil no matter what you try to do with it. I'd wait it out. Let it rain on it. As soon as it gets a few days to dry, you will be surprized at how good the hay is. You need to tedder (fluff) it out every day though when the sun finally comes out. If you don't have a tedder, you can change a bar rake height and yaw angle to tip it over. I've done it both ways. Even when it's rained for 2-3 days, the hay has come out good and fresh. A bit of color and weight loss, but better than a rotten load.
/ Baling green hay #3
Wait as long as possible and check it. I wouldn't bale it green or even if there are still clumps of green as its not worth the risk of fire. The only way I would even start to consider it is if you have a preservative applicator on your baler (and the moisture is close) or are doing rounds and are storing the hay outside.
/ Baling green hay
We plan to round bale it and store it outside. My brother may bale 150 square bales or so but that's it. Those would be stored inside.
Do you really think fire would be possible this time of year? I wouldn't think so due to the temperatures, but I don't want to risk it.
And thanks for the reply.
/ Baling green hay #5
I think fire is possible just about any time of the year if you bale wet hay and store it in a closed barn. Its going to generate heat and the hay will insulate it from most of the cooler outside air. Enough heat and a fire will start. Even if a fire doesn't start you will have a lot of moldy hay. I have been through this and have chose to not risk it and just pray the rain holds off. If it does rain I try to salvage it, if it keeps raining I just forget about it as that is how this game works:rolleyes:
/ Baling green hay #6
Let it be. I learned early on that hay baled green will rot, period. I have seen hay baled too green and put in the shed in the summer, set there all fall and catch fire and burn in January and February. All it takes is the smallest little clump of green hay to heat and catch fire, even though it may take months. A wise old farmer told me when I first started out, it will rot in the bale or it will rot in the field, but at least in the field you still have a chance to get it to dry, once it's in the bale, your done and the hay will be worthless. I have had hay get 2" of rain on it, then tedded it the next day and baled it that afternoon and it still was pretty good hay.
/ Baling green hay
We have always baled a little on the green side, before completely dry. My father did this for 40+ years and so did his father and never had any issues. We would store 1000+ square bales in a shed with no problems, but all round bales were outside. We'll see what it looks like this evening. Not sure what his reasoning was, maybe fermenting process or something?
/ Baling green hay #8
You've gotten very good advice from the other guys. It's not good for it to get rained on, but it's sure better than baling it green. And if you have it catch fire, you'll probably find it's the hard fire to extinguish that you ever fought.
/ Baling green hay #9
Well if you have always done this and your dad has always done this then why are you asking for advice?
/ Baling green hay #10
My father did the samething until one year; as I was feed the cows from hay stored in the barn. As I was removing the bales I found a space about the size of 1/2 of a bale of hay which was just ashes from were a fire started. Thank God it burned itself out before it caught the barn on fire.
From that day on my father wanted the hay dry before he baled it. He used to take some hay and twist it if he could twist juice out of the hay he left it to dry some more.
Just my thoughts.
Don
/ Baling green hay #11
I had a neighbor that baled some hay that was still a little green - square bales - and some of the bales did catch fire. Luckily he saw it in time and was able to put it out in his barn and then he had to clear the bales out of the barn and we could see them smoking ..the ones that had not caught fire were smoking and we opened some of the bales up and you would not believe how hot they were inside. Had he not been home and in the barn when the first bale ignited he would have lost it all..
/ Baling green hay #12
Green hay heats up and catches on fire as it dries. I have seen neighbors do it twice. One burned 30 acres and all his hay.
/ Baling green hay #13
Looks like you will be using a rake, like they said, Let it dry a day then rake it over.
It will depend on the size (depth) of your rows on how long you'll have to let it dry. You may try and get your hands on a moisture tester, darn handy tool.
What is he hay intended for ? cattle? As long as it isn't moldy and fertilized, it should be ok if you dry it. If it gets to wet forget it for horse in my opinion. After it's dry then you get to decide if iyts worth the cost of baling and storage ect tra.
/ Baling green hay #14
Cows will eat anything with some molases on it but Hprses are very picky.
Don
/ Baling green hay #15
If you choose to let it get a shower my advice would be not to fluff it again. Try to let it dry as naturally as possible. Holds its color better that way.
/ Baling green hay
I said a little on the green side, not really green. And second opinions and information is what this forum is intended for isn't it?
We baled late today, and it was pretty much dry. It was raked early and a breeze on it all day pretty much dried it out. The chances for rain are now 80% and estimated 4-5 inches of it.
/ Baling green hay #17
Yes, second opinions are what this forum is about as well as learning. But it seemed like you didn't like what any of us said and were mainly looking for someone to tell you what you wanted to hear.
I am glad everything worked out for you.
/ Baling green hay #18
Let it rain on it, then turn it. By "green" do you mean uncured? A good green color for hay is a sign of quality along with the correct moisture as it's baled. Hay that has been baled and stored can still cause problems if allowed to absorb moisture from the ground "mold" or water from overhead leaks causing mold and then heat. Round bales stored outside uncovered will cause less problems but have loss of quality in exposed surface faces. Have had some experience in small bale barn fires. Some total loss, some just discovered as heating progressed. In Eastern Oregon and in some parts of the Western United States big stacks 200ft., long by 30ft., wide and as high as they can loose/stack it are still used although not as much as 20 to 30 years ago. Hot spot fires didn't happen often.
/ Baling green hay
I guess my statement shoulda been freshly cut. There was plenty of dust so I know it was pretty dry. I wasn't sure how it would dry and knew it wouldn't be 100%, which no hay is 100% dry unless you let it sit for weeks and turning it I suppose. My main concern was if it didn't quite dry out.
We rolled it and it sit for a while and everything looked good. Oddly enough the sun was out and wind blowing so it dried pretty good.
I would have just let it sit until they started throwing out 5-6 inches of rain overnight. At first it was supposed to be Friday evening, but the weather folks upped it due to mother nature and the Gulf Coast. It's rumbling pretty good here now, so I'm hoping it was a wise choice. Thanks for the replies.
Wagon Wheel Bench (A64557)
Wagon Wheel Bench...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
JOHN DEERE 1790 - 12R30" / 23R15" VACUUM PLANTER (A64278)
JOHN DEERE 1790 -...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
