Tires Tire size -7710 II FWA 1990 model ??
   / Tire size -7710 II FWA 1990 model ?? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Just had my newly purchased Ford 7710 II 1990 w/ FWA unloaded at my local dealers lot. I am very pleased so far. I did not really pay much attention to the tire size when I purchased the tractor on Tractorhouse. Upon arrival, I noticed that the tires looked smaller than other 7710's I have seen. Also, one of the mechanics noted how low the steps are to the ground. I think this tractor came from flat farm ground but I have some pretty hilly and uneven terain here in NE Texas. The rears are 18.4 - 30 and the fronts are 18.4 - 24. All tires are in good condition with approx. 85% tread remaining and no apparent patches. My questions are:
1) Is this a proper "ratio" size of tire for FWA usage?
2) What would be a more common size front and rear tire for this tractor?
3) If I were to decide to put new tires on this tractor, would there be a market for the ones presently on mine, so that I could help offset the cost of a new set?
   / Tire size -7710 II FWA 1990 model ?? #3
I've had a few 7710's and they all had 16.9 38 on the rear and i can't quite remember but i think the fronts were 16.9 26....
What would be the potential results of operating the FWA if the tires were not properly matched to the front and rear ratios??
   / Tire size -7710 II FWA 1990 model ?? #5
The ratio is probably right..to put the little wheels on the back the 24's on the front are probably right....If it's wrong you'l see the tyres "kick" a bit.. no problem in 2wd but will eventually do damage in 4wd.
   / Tire size -7710 II FWA 1990 model ?? #6
My 7710-II had 34" rear tires but was 2wd so I can't say anything about the fronts. I am wondering if he has a special use 7710 that was used for right of way mowing or something similar where they wanted to lower the center of gravity.
   / Tire size -7710 II FWA 1990 model ?? #7
Buying an operator's manual for your new tractor will answer most of your questions.
Call 1-800-635-4913 to talk to someone at NH technical publications.
   / Tire size -7710 II FWA 1990 model ?? #8
I've seen 2wd's with 16.9x30's used in this application.
   / Tire size -7710 II FWA 1990 model ?? #9
It is one of the few applications I can think of where shorter tires would be an advantage. The other would be if you needed to use the tractor in a low headroom area like a barn or orchard.
Kubota B21 (A57148)
Kubota B21 (A57148)
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
Bucket (A55973)
Bucket (A55973)
New/Unused 13ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 13ft X...
2021 KOMATSU PC88MR-10 EXCAVATOR (A52709)
2021 KOMATSU...
