Acetylene Leak
/ Acetylene Leak #1
Beltzington
Appling, Georgia
JD 3720
My acetylene regulator has a slight leak where it attaches to the tank valve. I originally detected the leak by smell and just confirmed with soapy water. Remove the regulator and cleaned treads and fittings with a shop rag and compressed air. Reattached the valve taking care not to x-thread and tightened with a 12" crescent wrench to the point I would refer to as very snug. Still leaks. Should I:
- Tighten some more (Don't have an open-end torque wrench)
- Put some plumbers tape on the threads
TIA
/ Acetylene Leak #2
TIA
That's a flare connection I'm pretty sure so I don't think tape is gonna work only additional tightening might.
Check the flare on the regulator and the seat on the tank, around here you just swap tanks with the dealer when you need a refill so you never know what your gonna get, I tell them there's OSHA guys on my job and they are looking for safety violations, this way they give me the newest tanks.
I've never had a leak though even with just snugging the nut.
JB.
/ Acetylene Leak #3
Carefully check to see if the leak is caused by a crack in the pipe at the flare. These fittings take a lot of side load for various reasons....
/ Acetylene Leak
Thanks JB - That was easy enough, just went past my comfort factor with a brass fitting and tightened that mother down. No more leak. This was a swapped tank (my first) and even though it felt smooth I guess the there was a problem with the compression fitting.
/ Acetylene Leak #5
Well that may work for now but the whole idea of flare fittings is that you shouldn't need to "tighten the mother down" you could do damage to your regulator. I don't think compression fitting is really the right term, It's a flare and seat
For guys who transport them to and from jobs they need to be easily put on and off sometimes several times a day. I've never had to go more than just snug with the little 6" long torch accessory wrench.
ALWAYS keep your tanks shut off when not in use, not just shut off at the torch handle.
JB.
/ Acetylene Leak #6
My acetylene set up was leaking also. Looking in the tank valve there was the tiniest nick or dent. Put some fine grit emory cloth on a finger tip and sanded it out, still takes more tightening than I'd like but seals. When the tank empties I'll of course be given another in the swap, so maybe I'll get a better one.
2017 Ford F-450 Crew Cab Mason Dump Truck (A64556)
2017 Ford F-450...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
