Oh well, at least the day started good
   / Oh well, at least the day started good #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I was ready to finally start harvesting my corn today. The weather has been great for over a week allowing the field to dry up some. This particular field has wet spots that always give me problems so I was glad to get a good stretch of weather this late in the year. So I had to empty the dump trailer which was full of demoliton debris. Go to the transfer station at 7am and get told they no longer allow commercial guys to dump on Saturdays. But since I know them and they know I didn't know about the rule change they allow me to dump but can't fill out my slip till Monday. So first bullet dodged. I outfit the dump trailer to haul corn and head to the field. Get the first load harvested with only a few problems with wet spots (was able to get out of them without a tow). Haul the first trailer full in and notice there is a little more chaff then I want in there.
The first load was 4 ton and the moisture was 17.69. Not bad considering the guy unloading at the elevator in front of me was at 36. My turn comes up and the trailer won't dump so I have to shovel out two ton of corn before we got a booster there to charge the battery to dump the rest out. I am just glad corn flows so smoothly. I talked to the owner and ask about dumping another load today and one more tomorrow morning. He agrees as both dumps would be when they are closed so he would have to come over to meet me both times.
So I head back to the field. Make some adjustments to the harvester and can't get the chaff to go away. I turn the fan up to the point I am blowing corn out the back of the harvester and still have chaff in the bin. So I turn the fan back down and just live with the chaff as I need to get this load in so I can load a third load to deliver early Sunday morning. Half way to the elevator (20 miles away) I hear a loud boom:confused: followed by a strange noise. Ended up I blew out the right rear tire on my F-250 just as I started down a rather steep long hill. So I have to ride the truck on the blown tire all the way to the bottom till I am on flat ground to change it out. Its the first time I have had to use a spare tire in 10+ years. After fighting to get the tools out of the truck and dealing with a 5 ton trailer hooked to the back of the truck I finally get the truck jacked up and luckily the lug nuts came off easy. However the tire did not want to come off the hub. It took me 40 minutes to change a stupid tire:mad: all while the elevator owner is waiting just for me to get there. He was out on his bike earlier and came back just to let me unload. So I finally get there, unload all the corn by hand again as the battery is still dead and head home.
By now its too late for me to load a third load for the morning. The problem with the chaff is the shroud for the fan on the harvester broke loose and was hanging. So now I have to fix that tomorrow, the trailer is on the charger and hopefully it will work next time. I needed new tires fairly soon for that truck but didn't want to spend $900 for a set just yet. So I quit for today. Two loads of corn are in (about 8.25 tons). The second load of corns moisture was 17.4.
I am hoping the fields will dry out a little more tomorrow but there is a slight chance of rain tomorrow. Hopefully it will not come as we have another week of great weather ahead. I have at least two more loads left on these wet fields before I move to my gravel fields.
I really do love this work though. Running across the corn fields eating up the corn is just a lot of fun and relaxing for me. I just wish these little things wouldn't pop up as they take away from the overall day. I will load up tomorrow and haul that load in Monday hopefully.
I will try to get my dad to come out tomorrow and take some pics of the harvester to post here.
   / Oh well, at least the day started good #2
Interesting day Robert. Even with those "little things" popping up you still had a good day. Can't ask for much more than that. :)
   / Oh well, at least the day started good #3
Too bad you couldn't "farm out " - pun intended, the corn transfer to some local guy so he has to put up with the hassle of transport and you just sit back and fill trailers?
If I had a bigger harvester that I could fill trucks faster I could farm out the transportation. However, I can only harvest about 2 ton an hour with my harvester and fields. So any decent size truck would be sitting a while waiting to be filled. I can't unload into the tall dump trailers either. I am going to see about borrowing my friends dump trailer tomorrow and fill that as well so I can run them both in when I have the time. I just need to get this farm harvested before the rains come back again.
   / Oh well, at least the day started good #5
Too bad sliver creek is a little to far (Niagara) and i took it off the road for the winter last friday , but i have a dump truck that would make short work of that haulin problem. i bet this time of year you could get a truck to help you out down there. not much to haul now.
I have a friend who has a fleet of 10 and 12 wheel dump trucks but unless someone can just drop the truck off and leave it for a day I can't fill it fast enough. It would take me 10 hours to harvest 20 tons of corn and I don't want to be a hassle on others. So I make due and hopefully will be able to trade this dump trailer in on a larger one next year.
   / Oh well, at least the day started good #7
thats not too bad of a day, you still got some decent seat time even w/ the breaks. saw a jd 9400 harvester going down the road the other day minus the header, was surprised to see one in my area, but i think the local farms are starting to harvest it w/ a combine now instead of chopping it for forage, to earn some extra $$ these days w/ the ethanol boom and corn fuel for heating. robert, have you thought about any gravity wagons, or is the elevator too far to drag one of those?
   / Oh well, at least the day started good #8
I got you now, yeah I wouldnt want to make someone sit around all day either. A wagon would be nice if you could get a fixed tonge other wise that this would be snaking down thw rd for 20 miles
I used a gravity wagon last year and it would hold 5 ton. But it had no brakes and I was limited to 20-25 mph depending on the roads. I have to take the long way around when pulling the gravity wagon because of the hills the shorter way. The dump trailer allows me to drive around 55mph and take the short way. It holds 4 ton with my modifications so even though I have to make an extra trip I can do each trip in half the time of the gravity wagon.
The tube for the clean grain auger rusted through on me. I had repaired it last year but this time it rusted out where it goes through the frame. It is a mess and the only way I can fix it without tearing the entire machine apart is with duct tape and hope it works. Of course I can't try that now because when I shut it down yesterday it decided to crap out. Now it won't even turn over. I have to test the solenoid and a relay to see which one is causing the problem.
I am about ready to sell this machine. It is a nice machine but needs a ton of work which I have been hesitant to do since it doesn't really work that well for my operation. I hope to find a great deal on a used unit with RWA and a 4 row corn head now that most everyone is selling their harvesters to upgrade to newer, bigger ones like me.
I think it would be fun to restore this 3300 but I would not have the space to do it as it takes up a lot of room.
   / Oh well, at least the day started good #10
Robert: Where in Silver Creek do you find a long steep hill?
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
