Low utility bills with geothermal heat
   / Low utility bills with geothermal heat #31
Although not precise one can get a fair estimate of the heating and cooling costs in the spring and fall. When the windows are open.
   / Low utility bills with geothermal heat #33
Maybe an easier way to understand geothermal is in efficiency. If you are looking at a gas furnace that is 99% efficient the geothermal is 300% efficient on the same scale.
   / Low utility bills with geothermal heat #34
SuperCobra-- yeah, that's what I did, what whistlepig suggests: look over utility bills, and compare spring & fall usage with winter or summer, depending on your particular focus.
I found I was able to more or less isolate "normal" electric usage (whole house is electric- stove, washer, dryer, etc.) by looking at shoulder season usage, i.e., no heat, A/C or "it's dark at 5PM!!" lights.
Back when I did this, in 1988 or so, I found that my seasonal heat costs were just a bit less than the local folks who heat with wood-- about $350 for my 1800+/- sq. ft.
A year later, I found that if I purchased $150 worth of wood, cut, split & delivered (dry), I'd reduce my electric bills by the same amount.
It ain't the end of the world, but still a lot less than heating with oil or propane, at least in my area. Electric costs have certainly gone up, but I believe I still spend a lot less (a LOT less) than many folks around here for heat in the winter.
Interesting conversation when I got a telemarketing call about energy usage a while ago- "You use oil, right?" "No, I don't use oil." "Oh- then you use propane, right?" "No, I don't use propane." ....quite a long pause.... "So, how do you heat your house???" Followed by a long tutorial....:D
   / Low utility bills with geothermal heat #35
That when you say, "I heat with dirt"
   / Low utility bills with geothermal heat #36
We "guesstimate" our heating and A/C at $50.00 a month. No matter how bitter cold it gets or hot it gets the electric bill varies only a few dollars. A month of single digit temperature with wind chills of well below zero will only make a couple of dollars difference in the electric bill. It's flat as Kansas here and the wind is brutal.
   / Low utility bills with geothermal heat #37
Did any of you figure how many years it takes to recover the added expense of installing a ground source heat pump. 23 years ago when I was down to installing a heat system in the house I looked at the ground source systems and the cost for a 8 seer 3 ton rheem was about $3200 installed and a ground source system was 2 times that much and that did not include the loop install. I just replaced the 23 year old rheem with a Goodman 14 seer with a scroll compressor. Oh the house is 2400 square foot mid entry.
   / Low utility bills with geothermal heat #38
Interesting thoughts on open loop systems. Around here open loops systems have a return well or a drain tile about 5 to 7 feet deep. In theory all the water goes back to the ground. My last neighbourhood had lots of open loop systems. They do need a strong well. We can't put a loop in the lake nor can we take water, change the temperature and put it back. Either one would impact the fish habitat.
I had an open loop system in my last house and I'll put one in my new house next year.
A horizontal ground loop would be nice but there is no way the environment people would let me do that on my property.
   / Low utility bills with geothermal heat #39
That is the major drawback to geothermal. It is very expensive to install. Payback on the investment is a serious concern.
   / Low utility bills with geothermal heat #40
In 90 I bought a Rockton (installed as open loop) I forget the exact details but I do remember figuring it paid off in a year. The Rockton was a pretty simple machine. Cooling is passive, heat was 3:1 efficiency. That works up here. We typically only cool 10 days per year. When I put the house up for sale I replaced it with gas and took it with me.
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2006 Ford Econoline Wagon Van, VIN # 1FBSS31L26DA35612 (A57453)
2006 Ford...
2020 Chevy Silverado (A56438)
2020 Chevy...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
Forklift (A59228)
Forklift (A59228)
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
