charlz
Elite Member
If one side is worn more than the other side, you have a caliper issue.
I see now they are saying to replace the calipers along with the pads and rotors. Sure makes brake jobs look expensive these days.
I actually unhooked mine before I got the fix done- couldn't use the cruise, but I don't use it anyway
I'm just the opposite; I use the cruise control nearly every time I drive one of our vehicles. Just to go to the grocery store is 2 miles down the I-35E service road; 45 mph speed limit, and I just set the cruise.This sounds like the same recall I had for my 2001 Ford Ranger and got fixed on 8/6/2007. They didn't even take it back in the shop. The service writer just did it there on the driveway.
Major difference on regular replacement rotor vs. premium rotor is the
premium is made in USA.
HTH...
???? Charlz, you've lost me...
I'm about to put my 3rd set of rotors on my dodge truck. this truck eats brakes, and before I realize it, the rotors are toast.
And when I went to move the truck the other day, no brakes. Got a leak in the back line.
Oh, and the shop light ballasts are all junk.
Got one side done tonight, new rotor and brakes. The brake problem is the pads are just too tight from top to bottom, they won't slide. I need to grind it down to get some clearance.
No, no. Don't grind anything. You need to use a C clamp and squish the piston back into the caliper. Or, use giant sized channel locks.
edit: Yeah, what Bird said!! He types faster.
Anytime I grind or hammer something, it occurs to me a millisecond later why it wouldn't go together in the first place.![]()
