Mowing 2520 mowing question
/ 2520 mowing question #1
inseeme
Stoneville, NC
Kubota M7040
I just got an 06 2520 with a loader and mowing deck, my question is does John Deere make a valve where you do not have to unhook the loader if you want to raise your deck up and down? The mowing deck has never been put on the tractor and the previous owner had no clue, it is the 62d drive on mowing deck. thanks
/ 2520 mowing question #2
Hi,
I have the same set up with the independant lift kit. I assume yours is the same if you have to unhook hoses from Mowing deck to attach loader. John Deere makes a divertor kit that gives you 2 extra couplers for hydraulic hoses from your mower to remain plugged in at all times. You then get a plunger style "T" handle that directs the flow to wither the mower or curl function on the loader. In Canada they are $600 and in the US $474.
I had one on my 2320 that I just traded for a 2520 and I miss it. I'll probably install it on the 2520 but it is really more of a want than a need. I rarely have the FEL and MMM on at the same time.
Thanks,
Mario
that makes perfect since. thanks for your answer, this helps.
/ 2520 mowing question #4
This answer will be pretty lengthy, but I also have a new 2520 on order and it took a while for me to understand the various ways you can set up your tractor.
The tractor comes with a bank of 4 remote hydraulic couplers just under the right hand floorboard. These are used to connect the 4 lines from the loader, which then allows control of the loader through the Joystick.
Independent Lift, is a separate cylinder, which must be installed on the tractor, that will allow you to raise and lower the deck, independently from the 3PTH. In order to operate this "Independent Lift" cylinder, you must connect the 2 hydraulic lines to two of the ports of the remotes. If you do this, the deck will be raised and lowered also by the joystick control. This means you must disconnect 2 of the lines that would normally come from the loader, since the loader uses all 4 ports to operate all the functions.
JD sells a kit which is another set of couplers, that mount alongside the existing 4 ports, (Which then gives you 6 couplers) which will allow you to keep both the Independent Lift (for the mower deck) and the 4 lines for the loader connected at all times. In order to divert the hydraulic fluid to each implement, a "Diverter Valve" is used, which is part of the kit, and as I understand it, has a push/pull controller, which is mounted on the inside lower fender, where the operator can just pull or push it to divert the hydraulic fluid to the implement he wants to control.
Without a "Diverter Valve" kit, if you are using your mower, you would have to get off the tractor, and switch out the 2 lines controlling the deck to those that control the loader when you want to use it, because you will only have 4 remote connectors.
I opted to use the mechanical lift (3 PTH) to lift my deck, instead of the "Independent Lift" so I won't need this diverter valve. This means that I will raise and lower my deck with the rock shaft (3 PTH lever). I also opted for the "Deck Lockup Kit", which will allow me to lock the deck in the up position, which will thereby free the 3PTH to operate normally, with the deck locked up.
I also wanted to use my loader, and deck at the same time. To do this, it is much more economical to use the regular mechanical lift for the deck, otherwise you will need to buy not only the "Independent Mower Lift" kit, and if you want to keep all hoses connected at all times, you must also but the "Diverter Valve" kit, unless you want to switch hoses around every time you want to switch from mowing to loading.
In my case, by the time I bought both kits and had them installed, it was going to add $1200 - $1500 to the cost. I know this sounds expensive, but us Canadians always get hosed on the accessories.
I hope this helps explain things. I know I had a hard time understanding it, especially when most dealers immediately wanted to sell me the Independent Lift kit right from the get go.
REV
REV
F-450 SuperDuty Flat Bed 4WD (A63688)
F-450 SuperDuty...
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
UNUSED SDLANCH STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
John Deere Starfire 3000 (A64119)
John Deere...
