Transfer pump filter?
   / Transfer pump filter?
Ok Thanks again, I'll definitely get one that filters both water and particulates then. I guess I'll go with the spin type, I don't really need to be able to see the element I don't guess If for some reason the flow starts getting slow I can just replace the element.
   / Transfer pump filter? #12
*That's the general idea.
I'm going to install a filter on my electric transfer pump for my tractor fuel and was wondering what one would be better. I'm looking at either a metal spin on filer or one of the clear plastic bowls with the replaceable element.
Ok Thanks again, I'll definitely get one that filters both water and particulates then. I guess I'll go with the spin type, I don't really need to be able to see the element I don't guess.
* If for some reason the flow starts getting slow I can just replace the element.
Would sure like to see pictures of your pump and the rest of your set up .
I've built a couple of different set ups and posted pictures of both of them .
I'll get some and post up.
   / Transfer pump filter? #15
I've got this one on my pump. So far very happy with it.
Water-Block Fuel Filter - 0189579 | Tractor Supply Company
That's the sort of filter. Problem was, the local TSC didn't have a filter to match the pump I bought there :( I had to order from McMaster Carr.
McMaster Carr is really good at getting stuff shipped the same day and delivered quickly. I've actually had UPS deliver orders less than 24 hours after I placed the order! (And that's standard shipping.)
Our local TSC is poorly stocked. "If you need it, we don't have it". :(
Ken
Well finally got a pic of the pump mounted in the tank, I left the frame mounts on the tank so I can use my forks to pick it up and place it in the back of my truck or on my trailer if I'm doing a job away from home. All I have to do now is a little paint on the tank and mount the filter and reinstall my hose and nozzle.
   / Transfer pump filter? #17
What is the tank off of ?
It's off a Chevrolet Bob truck. They mounted under the cab, and had the step built into them to get up in the truck. It looks a lot better now that I have it painted.
   / Transfer pump filter? #19
- *I left the frame mounts on the tank so I can use my forks to pick it up and place it in the back of my truck or on my trailer
* I set mine up to be self unloading.
because I didn't want to have to mess with forks and the tractor to get it unloaded off my truck .
Here is a shot of me unloading.
   / Transfer pump filter? #20
How many gallon does this hold ?
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
WATER TRAILER (A58214)
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2022 Can-Am Defender XT HD10 (A59814)
2022 Can-Am...
2013 Ram 3500 Flatbed Truck (A59814)
2013 Ram 3500...
